How Long Can I Leave Zinsser 1-2-3 Primer On Walls? - Painting - DIY Chatroom Home Improvement Forum
Old 10-19-2011, 03:57 PM   #1
Smile
How long can i leave Zinsser 1-2-3 primer on walls?
Hello.. i would like to know how long can primer stay on walls without painting over? Will it affect the results if it's sit for too long?
I primed the walls with the water base primer on sunday but i've been working and havent had a time to paint over until tomorrow thursday, will i have the same results or will it be already too late and the primer is already cured and wont look as well?.
Thanks in advance!
LynniieRockz is offline   Reply With Quote
Old 10-19-2011, 04:00 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
You will be fine.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 10-19-2011, 04:21 PM   #3
Originally Posted by Matthewt1970 View Post
You will be fine.
Thank you by the way, i live in wisconsin so it is cold right now, im painting my bedroom and the temperatures are about during the day 49 or 52 and at night it goes down to 30's is it still ok to paint or will it cause the paint to peel or bubble?
Should i leave the heater on?.
Im using sherwin williams Duration latex paint
Old 10-19-2011, 04:46 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 614
As long as the room is above 50 you will be OK and the primer would be good for 30 days if need be. Sooner would be better.
The Following 2 Users Say Thank You to chrisn For This Useful Post:
Gymschu (10-19-2011), ltd (10-20-2011)
Old 10-20-2011, 10:33 AM   #5
jschaben
Rewards Points: 502
Is 30 days a real "drop dead" time for primer? I've got a partially finished project in the shop I primed with seal coat (it's pine) about 3 months ago. Do I need to reprime it?
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 10-20-2011, 04:29 PM   #6
chrisn's Avatar
Rewards Points: 614
Ahhh, tough one. I would guess if it has been protected from the weather you would be OK, but, hey, I just don't know Maybe Mr. Joe will poke his ugly maw in here and let us know.
Old 10-20-2011, 04:43 PM   #7
jschaben
Rewards Points: 502
Just been stacked on a shelf. Hadn't occurred to me that primer needed to be topcoated within a specific time frame
John Schaben
Old 10-20-2011, 04:56 PM   #8
Rubbin walls since'79
Brushjockey's Avatar
OK you MR sciences out there- If painting a latex on latex is considered no problem adhesion wise ( unless it's real high sheen and hard) , why would painting over an acrylic primer be any different?
I can see particularly exterior- where the primer wasn't really formulated to withstand the elements for any long period of time, but how about inside?
Sometimes I wish we had a chemist from Zinsser around...
By the way- Used Z's Smart Prime to hold back a nic room today- and I was impressed. Liking that primer.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 10-20-2011, 08:56 PM   #9
(the original)
Rewards Points: 756
John, what do you mean by "seal coat"? If you're talking about the Zinsser product by that name it's not primer, it's a light cut of shellac used as a sanding sealer. Recoat time on that is probably about the same as the half life of plutonium. Nothing to worry about.
ratherbefishin' is offline   Reply With Quote
Old 10-20-2011, 10:52 PM   #10
jschaben
Rewards Points: 502
That's the stuff - Thanks
John Schaben
Old 10-21-2011, 04:04 AM   #11
chrisn's Avatar
Rewards Points: 614
I already said, I don't know
Yes, that would be nice
I have not used any yet, I will keep it in mind, thanks
Old 10-21-2011, 06:33 AM   #12
Brush, thanks for the tip on the smart prime. I read the TDS. Looks good. I would suggest that those interested should read the TDS, as it has some finer points about dry times on various substrates,stains. I'm interested in a product that will replace Cover Stain. Not that I don't like it, but it's really, unfortunately, the only thing lately that requires me to carry oil supplies. BTW, my "ugly maw" is as lost as Brushjockey's on that question. There are just some things, some things, where I just believe and do as I'm told, lol. Topcoating over primers within a given time is one of them. For pros though, that's a situation rarely encountered.
Tags
primer
Primer Help Needed Improvised Painting 8 04-14-2011 07:45 PM
Finishing Basement Walls, Inside Perimeter Drains, and Moisture, Oh My BSponz1 Building & Construction 1 02-08-2011 01:20 PM
Oil based paint over Latex? No need for Primer? Jasonuncloned Painting 2 10-20-2010 10:33 PM
How long can I leave the air in compressor? norwei Safety 14 04-29-2009 07:47 AM
Blue masking tape: How long to leave on? digexpressions Painting 4 08-14-2008 04:56 PM
