How Long Can I Leave Blue Painters Tape On? - Painting - DIY Chatroom Home Improvement Forum
Old 03-05-2012, 07:31 PM   #1
Rewards Points: 2,212
How long can I leave blue painters tape on?
I usually cut in by hand but found it to awkward above the kitchen cabinets and seeing as I needed to tape and put poly up for texturing I figured I would tape before priming my ceiling.
I got the priming done but because of overtime at work and then going on a holiday I will not get around to texturing for about 4 weeks. I would like to leave the tape up so I can attach the poly to it (with more tape) But am thinking this is way to long.
So -- How long can you leave blue painters tape up and still get it off cleanly?
mae-ling is offline   Reply With Quote
Old 03-05-2012, 07:48 PM   #2
Rewards Points: 512
im not sure on the blue tape but the frog painters tape is 21days. i wouldnt take the chance and i'd retape it.
princelake is offline   Reply With Quote
Old 03-05-2012, 08:03 PM   #3
Rewards Points: 14,312
3M claims 14 days.
http://www.scotchblue.com/wps/portal...ock-Protector/
Old 03-05-2012, 08:41 PM   #4
Sometimes, on some surfaces, five minutes can be too long, and can pull finishes. As to it fusing to a surface, I don't care what the manufacturer says, I would pull it as soon as I'm done with it, or overnight if needed, but that's it. IMO, never four weeks, ever.
Old 03-05-2012, 08:46 PM   #5
Rewards Points: 582
my thougths too ..did a job finished on fri late in day....left blue tape till monday.what a mess.as you said pulled finish of other surface....alot of touch up not to mention upset customer...
Old 03-05-2012, 09:02 PM   #6
Ben, I did a job once where I had to protect some $eriou$ly expen$ive, exotic wallpaper to repaint some master suite ceilings. I bought the most delicate green tape. Had to keep resecuring it, it was so weak. But, it was strong enough to pull some the face off the paper. Ain't that some sheet? The protective measures actually did the damage. The customer's reaction, sheeeet, is a whole other story. He was away for the weekend, and I waited all day Sunday like a guilty child waiting for his dad to come home. It was a horrilble phone call. Everbody here, most especially BJ, knows my feeling about tape.
What parts of PA are you from?
Old 03-05-2012, 09:17 PM   #7
Rubbin walls since'79
Brushjockey's Avatar
I perfected my faux skills on wallpaper that tape had pulled chunks off on....
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 03-05-2012, 09:20 PM   #8
Rewards Points: 582
steel city...
Old 03-05-2012, 09:30 PM   #9
Originally Posted by ben's plumbing View Post
steel city...
Picksburg?
Old 03-05-2012, 09:45 PM   #10
Rewards Points: 582
Picksburg?
thats MR picksburgh to you you got it...
Old 03-05-2012, 10:20 PM   #11
So Ben, how does a plumber get to know painting?
Old 03-06-2012, 02:22 AM   #12
paper hanger and painter
chrisn's Avatar
Rewards Points: 618
You must have seen the messes that plumbers make, maybe ol Ben actually has learned how to fix them instead of leaving it for us to fix? Being from my now favorite city, this must be true
Old 03-06-2012, 04:29 AM   #13
It couldn't be the money!
Old 03-06-2012, 07:38 AM   #14
I removed it, Figured that was way to long but wondered what was Ok.
Old 03-06-2012, 01:52 PM   #15
bikerpowell's Avatar
About a month is what I would guess
bikerpowell is offline   Reply With Quote
First time taping - Tape has air under it theedudenator Drywall & Plaster 16 04-21-2010 11:13 PM
Aged Painting Tape Needs to Come Off user1007 Painting 2 03-04-2010 05:16 PM
How long can I leave the air in compressor? norwei Safety 14 04-29-2009 07:47 AM
Blue masking tape: How long to leave on? digexpressions Painting 4 08-14-2008 04:56 PM
a few ugly bubbles at blue tape line 1655graff Painting 4 01-17-2008 11:28 PM
