How To Light Sand Texture Ceiling - Painting - DIY Chatroom Home Improvement Forum
Old 03-11-2010, 01:42 AM   #1
Question
how to light sand texture ceiling
Planning to add silica sand (Lowes sells this in packs for a gallon) to regular water based ceiling paint. I want to have light sand texture, all the ceilings in the house are like this, so I want to keep this room the same way.
My question is can i use a regular roller (not a loop roller) , I plan to add half of what's recommeded for a gallon of teh silica sand.
Today I tried Bear Sand Texture paint (No. 1002), had to use a loop roller as per instruction, the finish was so heavy and so messy, I scraped it off before it got dry - ended up doing some light touch up with joint compound to fix the cealing.
If I add a gallon of ceiling paint to the Behr Sand Texture paint do you think it will work to thin it out to get a very light sand texture - so it canbe rolled with a regular roller?
Tom
mtom01 is offline   Reply With Quote
Old 03-11-2010, 09:49 AM   #2
Too Short? Cut it Again!
Put a bow on the can of Behr paint and donate the absolute crappiest paint on the planet to the in law you do not like. I can only imagine what Behr textured paint must be like given how awful the regular stuff is.
Stay out of box stores when buying paint, although I guess even Lowe's cannot screw around too much to cheapen silica paint additive?
Mix the silica into real paint store paint and put on a couple of coats with at least a 1/2" nap roller cover. I would use a thicker nap depending on how much texture you add but will leave that to you. No need for a specialty roller for a light sand finish--those loop things will make a mess with any paint.
Make sure you stir the paint often to keep the silica suspended as you go or it will settle to the bottom of the can.
Wrap the roller cover in plastic between coats. Toss it when you are done. IMO it is not worth gallons and gallons of water to rinse out a $3 roller cover and you will never get the silica out.
The Following User Says Thank You to user1007 For This Useful Post:
mtom01 (03-13-2010)
Old 03-11-2010, 06:14 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
What he said. (sdsester)
chrisn is online now   Reply With Quote
The Following User Says Thank You to chrisn For This Useful Post:
mtom01 (03-13-2010)
Old 03-12-2010, 08:07 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
Ayup
slickshift is offline   Reply With Quote
The Following User Says Thank You to slickshift For This Useful Post:
mtom01 (03-13-2010)
Old 03-13-2010, 01:11 AM   #5
Thumbs up
Guys thanks!
I got Homax - Roll on Paint Texture (Sand Medium Finish) from Lowes --Its Silica & Quarts , new wt is 6oz, and instructions says its good for a gallon of paint, and a 3/8" nap roller cover is recommended.
I primed a piece of drywall today to experiment first, hope this goes well.
Guess what I posted in Craigs list about the Bear sand Texture Paint for free - fot one reply saying I can keep it, seems that it will get to our township chemical disposal yard.
Help wiring ceiling light wylde8 Electrical 1 09-24-2009 07:29 AM
ceiling fan works, but light doesn't egildone Electrical 2 09-22-2009 12:20 PM
Light fixture in a drop ceiling? kosherdill Electrical 1 03-01-2009 01:23 PM
ceiling light power loss pejay Electrical 4 08-22-2008 06:02 AM
Ceiling light abuse! shurik57 Electrical 5 11-26-2007 11:30 AM
