How To Get Rid Of Dried Paint? - Painting - DIY Chatroom Home Improvement Forum
Old 11-09-2009, 06:24 PM   #1
How to get rid of dried paint?
I got a Purdy nylox Sprig at HD, when re dipping I notice dried paint on the side and near ferrule. The weather is not even hot. What wire brush would work best for cleaning?
StevenH is offline   Reply With Quote
Old 11-10-2009, 04:11 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 496
Any wire brush will work but you cannot be too aggressive or it will damage the brush. A brass one is not as abrasive.
Old 11-10-2009, 01:51 PM   #3
During painting time,Would a putty knife work for scraping off paint?
Old 11-10-2009, 05:48 PM   #4
chrisn's Avatar
Rewards Points: 496
Sure,or your fingernail works well also
Old 11-11-2009, 04:52 AM   #5
Remodeling Contractor
condition you brush prior to using it and you will avoid this. And cleaning will be much easier. If using water based paint, soak the brush in water prior to using it. If oil paint soak in mineral spirits. Now the paint will not soak up into the ferrule to start with.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 10:00 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
