How To Fix Inside Corner Bead - Painting - DIY Chatroom Home Improvement Forum
Old 07-07-2012, 02:17 PM   #1
How to fix inside corner bead
Hello everyone, I'm brand new to the forum and have a quick question regarding drywall.
I had my mother in law's home boyfriend how is a "contractor" and claimed to be an excellent drywaller which I welcomed because he was helping for free. It turned out to be a disaster, tons of mud and 2 weeks of sanding I thought I had gotten it to look decent enough to prime....so I did....WRONG. The inside corners look awful I didn't notice all the chunks and holes in the divots in the corner so I want to to fix it as best I can but I have no idea where to start? Can I tape and mud over the exisiting corner bead? should I rip it out? should I just skim the chunks over the primer, sand and re-prime? Any advice would be greatly appreciated I am not rich and I cannot hire a professional so you are all my only hope.
Any suggestions would be greatly appreciated.
Thank you.
Dunham19 is offline   Reply With Quote
Old 07-07-2012, 02:28 PM   #2
the Musigician
DangerMouse's Avatar
For the best answers here, photos would be greatly appreciated.
DM
Old 07-07-2012, 02:33 PM   #3
Too Short? Cut it Again!
Pics for sure. Usually inside corners are just taped. Are you saying some sort of protective material like for outside corners was used backwards? I am confused. You do know the answer to some of your questions already though right. Should you? Usually drywall f-ups do not get better just adding more material to compensate.
Tell us what tools you have too please? We will get you through this.
Old 07-07-2012, 02:39 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
Not really sure how to answer this- sure you can fix stuff- do you know how?
Do you have a 12', 6" and 4" mud blade?
Corner bead is used on outside corners, inside ones are usually taped.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 07-07-2012, 02:49 PM   #5
Workaholic's Avatar
Rewards Points: 268
Take some pics so we can get a clearer idea as to what you have going on.
Sean
Workaholic is offline   Reply With Quote
Old 07-07-2012, 04:27 PM   #6
Unfortunately I cannot take pics, and after looking at it, i'm guessing it's just tape but when I talk to him he says corner bead....i have most tools..i can't think of anything I would need that I don't. I just really want the room to look nice and I'm thinking I should tear out the corner and start over but I'm afraid of damaging the drywall so bad that I'll end up replacing the drywayy....it is just the corners that have not turned out.
Old 07-07-2012, 04:38 PM   #7
Use a drywall knife and cut either side of the tape you want to remove - limit the damage.
Old 07-07-2012, 04:39 PM   #8
I would take a razer knife and cut away a small section so you know what you have. If he nailed or screwed in some sort of metal bead, you will have to move with caution. If it turns out to be tape, score (if you can) down the edge and slowly pull it loose. Remove the extra mud and do it over.
Old 07-14-2012, 05:23 PM   #9
Hey guys, thanks for replying...I ran into a busy week and just got back to this. I cut out the old tape and put a new strip in the corner I mudded 1 side and I'm letting it dry before I mud the other so as not to cut into the wet mud. I was at Home Depot and talking to one of the employees who recommending just using a corner trowel and that would create a really nice finished corner....is this true? Does a corner trowel make more sense for me to use in place of a straight edge? Any thoughts on this?
Inside corner Deck constructions handycuzofdad Building & Construction 0 06-04-2012 09:46 PM
Corner bead question Aloha1 Drywall & Plaster 10 02-21-2012 09:38 PM
Framing Support for Inside Corner on L-Shaped Stairwell jsoares4 Carpentry 5 01-24-2011 07:25 AM
J Bead?? Or traditional 90 degree corner bead ryan5068 Drywall & Plaster 2 05-14-2010 10:18 PM
Corner Bead for Double Drywall? whipper Drywall & Plaster 11 08-12-2009 01:19 PM
