-   -   How do you use a loop roller? (http://www.diychatroom.com/f4/how-do-you-use-loop-roller-2094/)
redline 03-21-2006 04:49 AM
A friend needs to hide small imperfections on his ceiling and wants to use a loop roller. Can the loop roller be used with joint compound to add texture to the ceiling?
How is this done?
Can he use the loop roller to apply textured paint to the ceiling?
If so, how is this done?
thanks
slickshift 03-21-2006 06:25 AM
Never heard of it
Maybe it's called something else around here?
jbfan 03-21-2006 08:36 AM
See my reply to your other question above.
redline 03-21-2006 07:26 PM
thanks
gman 03-28-2006 06:20 PM
Loop roller
Redline
I have used the loop roller, paint stores called texture roller etc.
I first trowel on the drywall mud about 1/8 thick don't worry about being exact. Then roll with a light touch. roll just one way and you one design.
Also you can use a songe Also they a a brush with two heads just for this purpose.
good luck
Dale 04-07-2006 10:44 AM
Textured Finish
1 Attachment(s)
Hi Redline,
You can ususally buy texture ready mixed in containers, here in the UK it is sold at most diy stores, either the more popular powder, or more expensive ready mixed, but if you need to texture an area say for patching you have to make sure that the consistency of the texture resembles that of the already patterned surface when that was mixed and used for the original design.
Texture, or drywall powder is waterbased, this means it can be thinned down to make a wetter compound, creating textures of various consistencies, which is important for patching an already textured surface
For a more professional and easier to acheive textured finish, it is best that the surface to be textured is sealed first, this will help the applied texture coating, stopping it drying off too quickly whilst your working it, thus helping it bond to the surface (and preventing it shrinking back into the surface, preparation as you know is most important)
If the surface to be textured is very porous already, you must use a sealer or pva, (unibond or watered down vinyl silk emulsion) and when dry this will leave a sheen, this is now good to texture onto, also the room is best cold when your texturing as heat usually dries the texture off too quickly
The correct method is to make sure you have enough mixed texture to complete the area to be textured, thin your texture coating to the right consistency depending on what patten/design you are doing, then
using a synthetic or lambs hair roller, roll onto the ceiling, in bands, across the width, about two foot wide & half inch or more thick, (depending on the depth of the design you are attempting) try to keep it reasonably "even" as a thickly rolled area here and there will show in the final finish
Then using your texturing tool that you have to create the pattern (roller, brush, sponge) prime this by dipping it into the mixed texture and begin your design, texturing the coated area, once complete roll on the next section and continue, it is nice to finish the job by using a 1 inch paint brush to cut around the perimeter of the textured ceiling
I hope that this helps you and good luck, if you would like more information on the "correct interior surface preparation", "texture repairs", "how to make that pattern" & "texturing" as an alternative attractive ceiling & wall coverage please feel free to download my info sheet below
http://lulu.com/items/volume_10/2180...E_DOWNLOAD.pdf
or type TEXTURE REVIVAL into google search
for more info please feel free to e-mail me or post your questions here
Regards
Dale Ovenstone
Dale 04-14-2006 04:15 PM
creating designs using "TEXTURING COMBS"
Can I just add to the above comment that you can also create many eye catching designs & patterns onto your ceilings and walls using "texturing combs" of various sizes and shapes by drawing or sweeping them through the applied texture coating, these are normally made of a rigid but flexible plastic with a toothed edge & has a wooden handle to grip it with
If you would like more information about "texturing combs" send me an e-mail at d.ovenstone@ntlworld.com and in the "subject line" just type in freecomb
Regards
Dale
redline 04-15-2006 02:43 PM
thanks
Minivicky 04-02-2013 09:05 AM
will a textured roller give me a texture if I use regular paint? Or do I have to use a drywall paste to get the texture?
