Old 09-07-2009, 10:54 AM   #1
How do you smooth painted mudwork
Recently purchased a home and I am trying to redo the bathroom. The mudwork over the wallboard seams was never sanded and looks like it may have one or two coats of paint over it. I tried sanding with just regular sand paper and it would not cut through the paint. I even tried the orbital sander..that burnt a circle on the wall.
What is the best way to smooth the seams out? Unforutantely I have 3 of them from ceiling to floor. Possibly going over the area with a joint compound or would that make an even bigger mess??
Any advice is greatly appreciated.
Jake's Mom is offline   Reply With Quote
Old 09-07-2009, 02:39 PM   #2
Matthewt1970's Avatar
Use joint compound. You will be sanding all day if you dont. Do 2-3 skim coats and sand. Prime the patched area and paint away.
Old 09-07-2009, 03:42 PM   #3
JMDPainting is offline   Reply With Quote
Old 09-07-2009, 09:12 PM   #4
Painting Company, NY
housepaintingny's Avatar
I agree with using the joint compound. You'll never sand those spots down, beings they have been primed and painted already. Apply some new compound at the edges of the old compound in the low spots and feather it out. Apply a couple of thin coats until you've achieved the desired look you want, sand, prime, paint.
housepaintingny is offline   Reply With Quote
Applying texture on smooth cement interior walls Flt_Simulation Remodeling 8 05-14-2009 06:23 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
Refinish painted drywall broadbear General Discussion 1 03-29-2009 01:48 PM
How to smooth out serious roller texture? beerdog Painting 7 12-29-2008 06:58 PM
Smoothing out a painted and not painted drywall surface MarksHouse Drywall & Plaster 5 10-21-2008 12:50 PM
