How Do You Paint PVC Pipe Or Lattice? - Painting - DIY Chatroom Home Improvement Forum
Old 05-08-2008, 03:24 PM   #1
How do you paint PVC pipe or lattice?
In my case I'm painting PVC white lattice to the color of my deck. My question: What primer would I use before painting final color? I did one small piece of white PVC lattice with just 2 coats of latex paint. After 2 days of drying I can scratch the paint off with my thumbnail exposing the white of the PVC.
Thank you
Andrew
AndrewC is offline   Reply With Quote
Old 05-09-2008, 08:16 PM   #2
Rewards Points: 28
Xim
Well there are a few great exterior primers out there.....FOR PLASTIC OR PVC, I would go with a primer from SW called XIM. We have had huge success with this product on lots of surfaces, especially "PVC", plastic or fiberglass front doors and windows.
Just be careful, it can be tricky to work with and it's about $30-35 a gallon in our area, (Florida).
But, let me assure you,
you can prime slick glass with this and paint will stay. Good stuff~
BTW, always better to remove the "sheen" that the lattice will have, but not necessary with a primer such as XIM. This can be done with a liquid deglosser (caution: the good ones can be harsh).
Pro Color Painting
Pro Color is offline   Reply With Quote
Old 05-09-2008, 09:42 PM   #3
remodeling pro
As ProColor says, prime with XIM from Sherwin Williams. Just as a note, this is the recommended primer from the pvc trim manufacturers, like Azeck. This is a "bonding" primer and will hold any quality top coat. Be sure you work in well ventilated area, as it is a xylene based product, and quite potent.
troubleseeker is offline   Reply With Quote
Old 05-10-2008, 02:45 PM   #4
Thank both you guys.
I just seen both of the replys to my question and I really thank both of you guys for answering my PVC question.
Thanks again
Andrew
Old 05-10-2008, 05:00 PM   #5
Rewards Points: 28
Anytime Andrew......good luck~
Pro Color LLc
Backing off OLD galvanizd pipe...& PVC to cast iron michael76 Plumbing 13 02-17-2009 11:18 PM
Paint coming off of siding ciera Painting 5 07-01-2007 05:22 PM
Replacement pipe for hot water heat? Tmb9862 HVAC 18 01-12-2007 03:31 PM
Need to support 15th of ABS pipe irishtimes101 Plumbing 3 09-01-2006 11:09 AM
