How Do You Paint A Concrete Block Foundation? - Painting - DIY Chatroom Home Improvement Forum
Old 06-09-2011, 09:48 AM   #1
Wink
How do you paint a concrete block foundation?
I just removed faux stone and it looks nasty. I want to paint it black to match the house. thanks!
hanleyster is offline   Reply With Quote
Old 06-09-2011, 06:27 PM   #2
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
H&c solid concrete stain. Or you could apply a masonry primer such as loxon from SW and two coats of a quality acrylic latex paint, but the concrete stain eliminates the step of priming. The stain can be found at SW.
housepaintingny is offline   Reply With Quote
Old 06-09-2011, 07:14 PM   #3
Gymschu's Avatar
Rewards Points: 1,020
Well said HPNY. Also, make sure to gently clean or wire brush any loose or peeling paint that's on there now. I say gently because block foundations can literally crumble away from a strong pressure wash or aggressive scraping.
Gymschu is online now   Reply With Quote
Old 06-10-2011, 03:13 PM   #4
Ironlight's Avatar
You might consider stuccoing it instead. You can color it and that will give you a better looking surface than the concrete block, and you have enough of it exposed that I think that's a better aesthetic option with much lower maintenance.
Ironlight is offline   Reply With Quote
Bathroom Remo: Is this Plaster over Concrete Block? Mounting Backerboard over top? itcanadian Remodeling 10 03-21-2011 12:06 PM
New Concrete Block for foundation under ground. LuigiT Building & Construction 6 10-29-2010 09:09 PM
Concrete Repair Help / Contractor Problems thp Building & Construction 12 09-24-2009 01:01 PM
concrete paint removal before tile installation SR996 Flooring 1 03-21-2009 07:31 PM
Concrete Block Foundation Questions project_guy Building & Construction 1 05-09-2008 09:16 AM
