How Do You Paint An 18 Ft High Wall, Along A Stair Case? - Painting - DIY Chatroom Home Improvement Forum
Old 07-17-2010, 09:00 PM   #1
Lightbulb
Hi all,
Our living room has 18 foot high ceilings, including the wall along the stairs. We've never painted that room because of that but we're interested in doing so now.
We will be able to get ahold of a very tall ladder for most of that room, but we obviously cant put the ladder on the stairs, so how do we go about painting that particular wall?
Also, we can probably use a long handled roller for most of it, but there's still the matter of cutting in along the ceiling, so a roller wont do.
Any ideas? Are there ladders/scaffolding made especially for stairs? This one has stumped us for years. If anyone can give us an idea on how to successfully paint the wall by the stairs, I'll dub you my official hero of the day.
OOPs! I titled that wrong. I meant to say, an 18 foot high WALL.
Danijo is offline   Reply With Quote
Old 07-17-2010, 09:11 PM   #2
Roller & a long pole
And/OR build a platform that can be removed
General idea : --not my kids or pic
Once my son's older I can get him climbing ladders & painting
His jungle gym is much higher then this platform & more dangerous IMO
Old 07-17-2010, 09:17 PM   #3
Electrician
Proby's Avatar
To expand on Dave's post, an A-frame ladder and a plank will work for most situations.
You can get an expandable model like the one I linked to below, with that you can have it set halfway up the stairs and have the ladder on the floor at the bottom and work across the whole wall.
http://www.lowes.com/pd_56149-287-PA...14_4294937087_
Proby is offline   Reply With Quote
Old 07-17-2010, 09:58 PM   #4
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Originally Posted by Danijo View Post
Hi all,
You can use an extension ladder with adjustable legs on it, or an extension ladder with a ladder pivot, or set up scaffolding with adjustable sides, then cut in what you have to cut in and then roll the walls with a roller on an extension pole. I would have to see exactly how much wall space there is to paint in order to determine the easiest metho and also if the ceiling was beeing painted or not.
housepaintingny is offline   Reply With Quote
Old 07-18-2010, 04:17 AM   #5
paper hanger and painter
chrisn's Avatar
Rewards Points: 150
Why would that matter?
Old 07-18-2010, 06:40 AM   #6
Rewards Points: 616
Because for me personally I would Probably just use a ladder, but if I was painting the ceiling too and had a lot of cutting, maybe around lights too, then I would set up the bakers rack. Depending on witch method would save me time.
Old 07-18-2010, 07:46 AM   #7
Thanks everyone for the advice so far
There's actually not one single ceiling light in our living room, it's all lamps. So we dont have to go around anything on the walls. It's an odd room to say the least. The reason the ceilings are so high is because the upstairs has a balcony so the floor only comes across half way..so instead of there being a floor to the upstairs, its just all open walls/ceiling .. If that makes ANY sense at all (probably not). Sorry for the confusing descripting. It's early, I'm tired, you know how it is.
I can only take pictures by my cell phone right now and its dark in that room anyway, so theres 2 strikes against me, but later today if it gets bright enough I'll see if I can get a good picture of the wall I'm talking about to post.
Old 07-18-2010, 10:07 AM   #8
Electrician
Proby's Avatar
Maybe now, while you have scaffolding setup and before paint goes on the ceiling, it's time to have some lights/fans installed up there?
Old 07-18-2010, 06:21 PM   #9
chrisn's Avatar
Rewards Points: 150
Ok, got it.
Old 07-18-2010, 09:14 PM   #10
I had to paint my front room recently and I have a 16ft cathedral ceiling that I ran into the same issue with. What ended up working for my was I bought a used ladder of craigslist that was like the little giants ladder. There were several different folding set-ups to make this ladder work with the stairs and I could make it a 16ft straight ladder, 8ft a-frame when fully opened up or 12ft with a 4ft pivot, etc. It worked out great.
Heres how my front room was just for reference. Can't really see the ceilings of it but you can see the stairs I dealt with.
fox_forma is offline   Reply With Quote
Old 07-18-2010, 10:07 PM   #11
Finisher
Just thought i'd point that out. If you don't know how to do it, you probably shouldn't.
That said, an extension ladder with adjustable legs will work (just make sure they're attached properly). An aluminum plank and a multi-ladder will also work, as will an extension and a pivit ladder tool.
Rcon is offline   Reply With Quote
Old 07-19-2010, 01:53 PM   #12
Rewards Points: 252
This would be a perfect commercial for a little giant ladder. I had a similar situation in my old house and used bakers to do the ceiling, a little giant on the stairs, and for one really hard place I used one of those brush holders that go on the end of an extension pole....
mazzonetv is offline   Reply With Quote
Old 07-19-2010, 02:10 PM   #13
Household Handyman
Rewards Points: 1,408
My daughter-in-law's brother is a painter. I've seen him do this particular situation many times--no ladder. He has a long pole which has a clamp type device on the end to hold a brush and can be set an angles. He just puts a roller pan over there, dips the brush in it, taps it off, raises it and cuts it in. I cannot do this, I've tried, and he laughs. No joke, he just cuts it in. IF, and I say, IF--he gets paint on the ceiling, he just goes back with the color of the ceiling and touches it up. It does take experience but by the time I can get a ladder set up--he's done. David
Old 07-19-2010, 02:39 PM   #14
Handyman
Rewards Points: 512
David's right...done that many times. It takes a lot of patience and a very steady hand/arms. Just go slow.
canadaclub is offline   Reply With Quote
Basement Concrete Wall Framing Against Stairs Epicsoccer Remodeling 7 01-13-2013 04:11 PM
Advice on retaining wall replacement (pics inside) eastie Building & Construction 0 04-05-2010 11:32 AM
Removing spine wall beko Building & Construction 12 02-02-2010 02:15 AM
Best High Temp Paint for wood stove?? Sellncars Painting 9 01-21-2009 07:21 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
