How Do You Get A Sandy Texture Finish When Painting In The House - Painting - DIY Chatroom Home Improvement Forum
Old 11-15-2011, 12:01 PM   #1
How do you get a sandy texture finish when painting in the house
mjeffersondc is offline   Reply With Quote
Old 11-15-2011, 12:09 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
I see you have supplied a map. Are we having a party at your house?
The Following User Says Thank You to Bud Cline For This Useful Post:
Snav (11-15-2011)
Old 11-15-2011, 12:10 PM   #3
No This was my first post and I have no clue what I am doing.
Old 11-15-2011, 12:14 PM   #4
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Well darn! I was looking forward to a party.
There are several painters around here that can answer your question but until they show up I can tell you that you could simply add sand to your paint. But not just any sand. I think silica sand is normally used.
Old 11-15-2011, 12:45 PM   #5
Gymschu's Avatar
Rewards Points: 932
Most of the major paint companies make an actual paint with sand texture already premixed. I don't think you can get the full range of colors like regular paint, but there is a pretty good selection of colors in the sand texture palette. Premixed is the way to go......it eliminates the guessing game of how much sand to mix into your paint.
The Following User Says Thank You to Gymschu For This Useful Post:
Bud Cline (11-15-2011)
Old 11-15-2011, 01:02 PM   #6
Thank you for the info. Sorry about the party
Old 11-15-2011, 01:04 PM   #7
Thank you gymschu and bud cline. I did not know about silica sand. Would home depot have it? Also, I will look into sand textured paint. I need a medium to light brown.
Old 11-15-2011, 01:10 PM   #8
Tileguy
Bud Cline's Avatar
Rewards Points: 558
Home Depot should have silica sand, it is used as an abrasive for sandblasting but should be found with all the other bagged aggregates. Just keep track of how much sand you add to a gallon of paint so you can duplicate the recipe later.
Old 11-15-2011, 01:22 PM   #9
Thank you
Old 11-15-2011, 01:30 PM   #10
Old School
Willie T's Avatar
I want the party. You are only a little over 2 hours and 30 minutes away from me.
Willie T
Old 11-15-2011, 02:57 PM   #11
Maybe we can all have a couple beers one day.
Old 11-15-2011, 05:53 PM   #12
ltd
Rewards Points: 536
sand texture , you can get it at lowe's in the paint dept. comes in a little box that says sand texture. cost under five bucks i think. it will tell you how much to mix in a gallon .if it were me i would use less than more ,you can always add but you cant take away once its in the paint i used this last month and it worked good
ltd is offline   Reply With Quote
Old 11-15-2011, 08:29 PM   #13
NACE Coating Inspector
mustangmike3789's Avatar
Originally Posted by willie t View Post
i want the party. You are only a little over 2 hours and 30 minutes away from me.
same here. I will bring the PBR and GRAPE MAD DOG for the trailer park bombs.
mustangmike3789 is offline   Reply With Quote
Painting the texture on my walls and not sure of color options Dinaya Painting 0 10-08-2011 10:22 AM
How does a person figure a bid for sheetrock finish and painting? michell Painting 3 08-11-2008 04:23 PM
Painting the "sunny sides" of the house Beth777 Painting 10 07-18-2008 12:25 PM
Painting exterior wood house parasailing Painting 1 02-06-2006 01:24 PM
My dilemma: Painting exterior of house dvarga Painting 6 08-26-2005 09:23 AM
