-   -   How do you get a sandy texture finish when painting in the house (http://www.diychatroom.com/f4/how-do-you-get-sandy-texture-finish-when-painting-house-123542/)
mjeffersondc 11-15-2011 12:01 PM
http://maps.google.com/maps/api/stat...00&sensor=true
Bud Cline 11-15-2011 12:09 PM
I see you have supplied a map. Are we having a party at your house?:)
mjeffersondc 11-15-2011 12:10 PM
No :) This was my first post and I have no clue what I am doing.
Bud Cline 11-15-2011 12:14 PM
Well darn! I was looking forward to a party.:)
There are several painters around here that can answer your question but until they show up I can tell you that you could simply add sand to your paint. But not just any sand. I think silica sand is normally used.:)
Gymschu 11-15-2011 12:45 PM
Most of the major paint companies make an actual paint with sand texture already premixed. I don't think you can get the full range of colors like regular paint, but there is a pretty good selection of colors in the sand texture palette. Premixed is the way to go......it eliminates the guessing game of how much sand to mix into your paint.
mjeffersondc 11-15-2011 01:02 PM
Thank you for the info. Sorry about the party :)
mjeffersondc 11-15-2011 01:04 PM
Thank you gymschu and bud cline. I did not know about silica sand. Would home depot have it? Also, I will look into sand textured paint. I need a medium to light brown.
Bud Cline 11-15-2011 01:10 PM
Home Depot should have silica sand, it is used as an abrasive for sandblasting but should be found with all the other bagged aggregates.:yes: Just keep track of how much sand you add to a gallon of paint so you can duplicate the recipe later.:)
mjeffersondc 11-15-2011 01:22 PM
Thank you :)
Willie T 11-15-2011 01:30 PM
I want the party. You are only a little over 2 hours and 30 minutes away from me.
mjeffersondc 11-15-2011 02:57 PM
Maybe we can all have a couple beers one day. :)
ltd 11-15-2011 05:53 PM
sand texture , you can get it at lowe's in the paint dept. comes in a little box that says sand texture:huh:. cost under five bucks i think. it will tell you how much to mix in a gallon .if it were me i would use less than more ,you can always add but you cant take away once its in the paint :huh: i used this last month and it worked good
mustangmike3789 11-15-2011 08:29 PM
Originally Posted by willie t (Post 771796)
i want the party. You are only a little over 2 hours and 30 minutes away from me.
same here. I will bring the PBR and GRAPE MAD DOG for the trailer park bombs.
