How Do I Remove Textured Paint Without Taking Whole Ceiling Down - Painting - DIY Chatroom Home Improvement Forum
Old 08-04-2006, 12:44 PM   #1
how do I remove textured paint without taking whole ceiling down
I'm painting a room, and the ceiling has textured paint on it. Is it possible to remove the textured paint without taking down the entire ceiling?
johnsuchow is offline   Reply With Quote
Old 08-04-2006, 02:20 PM   #2
Rewards Points: 150
If you're talking about popcorn ceiling, the texture can be removed by spritzing with water and using a putty knife to scrape it off. If there's many coats of paint on top, you may have to score it with something before spraying it. Don't use too much water or you'll also scrape off the facing for the drywall.
billinak is offline   Reply With Quote
Old 08-04-2006, 08:32 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
Depends on the texture
Is it popcorn, sand, or more of a swoopy plaster thing?
slickshift is offline   Reply With Quote
Old 08-17-2006, 10:38 AM   #4
I guess it's sand.One fellow said to spritz with water.
Old 08-17-2006, 08:19 PM   #5
slickshift's Avatar
Originally Posted by johnsuchow
I guess it's sand.
OK
Uhh...No
That would work for "popcorn", not for sand
Sand means scrape with putty knives (wide ones) and get as much off as you can
Then power sand off as much as you can as smooth as you can
Then prime whats left
Then skim coat some joint compound over the lumpy bits to smooth out and blend them into the now smooth parts
As many coats as needed
Then re-prime
Then paint
Old 09-09-2008, 09:42 PM   #6
wavy plaster
How do i remove it if it is a wavy plaster type ceiling?
fsumike21 is offline   Reply With Quote
ceiling paint in bathroom gorilla325 Painting 15 09-10-2012 06:07 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 08:26 AM
Ceiling Paint CeeZee Painting 12 09-22-2010 12:07 PM
Taking paint OFF the ceiling! anniegoff Painting 3 04-16-2007 04:09 PM
How do I remove stucco from a ceiling painted with oil paint labnotes Painting 4 01-09-2007 10:26 AM
