-   -   how do I remove textured paint without taking whole ceiling down (http://www.diychatroom.com/f4/how-do-i-remove-textured-paint-without-taking-whole-ceiling-down-3323/)
johnsuchow 08-04-2006 12:44 PM
I'm painting a room, and the ceiling has textured paint on it. Is it possible to remove the textured paint without taking down the entire ceiling?
billinak 08-04-2006 02:20 PM
If you're talking about popcorn ceiling, the texture can be removed by spritzing with water and using a putty knife to scrape it off. If there's many coats of paint on top, you may have to score it with something before spraying it. Don't use too much water or you'll also scrape off the facing for the drywall.
slickshift 08-04-2006 08:32 PM
Depends on the texture
Is it popcorn, sand, or more of a swoopy plaster thing?
johnsuchow 08-17-2006 10:38 AM
I guess it's sand.One fellow said to spritz with water.
slickshift 08-17-2006 08:19 PM
Originally Posted by johnsuchow
I guess it's sand.
OK
Uhh...No
That would work for "popcorn", not for sand
Sand means scrape with putty knives (wide ones) and get as much off as you can
Then power sand off as much as you can as smooth as you can
Then prime whats left
Then skim coat some joint compound over the lumpy bits to smooth out and blend them into the now smooth parts
As many coats as needed
Then re-prime
Then paint
fsumike21 09-09-2008 09:42 PM
wavy plaster
How do i remove it if it is a wavy plaster type ceiling?
