Old 01-07-2007, 04:34 PM   #1
Smile
How do I remove stucco from a ceiling painted with oil paint
I have stucco on the ceiling that has been painted over with oil bases paint. Is there a way to remove the stucco so the ceiling can just be painted.
labnotes is offline   Reply With Quote
Old 01-07-2007, 05:51 PM   #2
Long-Time DIYer
Mike Swearingen's Avatar
I'm not a pro contractor, but IMHO, it would be more economical (and look much better) to cover it with 3/8" drywall, and then finish, prime and paint it.
Mike
Mike Swearingen is offline   Reply With Quote
Old 01-07-2007, 08:03 PM   #3
Is this actually stucco or are you talking about "Popcorn" on the ceiling
amazinlittledevil is offline   Reply With Quote
Old 01-09-2007, 05:51 AM   #4
If its popcorn you can wet it, scrape it off, and skim. If its a floated texture (skip trowled or "stucco") you're better off hanging a new ceiling over it as stated above.
Kennedy is offline   Reply With Quote
Old 01-09-2007, 11:26 AM   #5
If it is popcorn you may want to have it tested for asbestos depending on when it was applied. I had popcorn on a ceiling and wanted to remove it. I searched online for instructions on how to do it and one of the first things I found was that it would be wise to have it tested for asbestos. I did and sure enough it was there. It was used for a long time in popcorn ceilings as sort of a bonding agent. Anyway it channged my mind about removing it.
I agree with Kennedy's advice though on how to remove it.
Clint
ceiling paint in bathroom gorilla325 Painting 15 09-10-2012 07:07 PM
Paint peeling off Bathroom Ceiling!!! armen30 Painting 17 12-08-2011 09:26 AM
Ceiling Paint CeeZee Painting 12 09-22-2010 01:07 PM
how do I remove textured paint without taking whole ceiling down johnsuchow Painting 5 09-09-2008 10:42 PM
Taking paint OFF the ceiling! anniegoff Painting 3 04-16-2007 05:09 PM
