Old 10-31-2009, 08:28 PM   #1
Default How do I remove splatter from shingles?
Is there a good way besides using a power washer to remove latex paint off of asphalt shingles?
I have an overhang where soffit goes directly over the shingles. When I painted the soffit, I also got paint on the shingles. It's white SW super paint on a dark gray shingle, so it stands out.
It will never get direct rain or sun light, so I don't see it fading to much over time.
ConstantChange is offline   Reply With Quote
Old 10-31-2009, 10:46 PM   #2
Default Paint splatters on shingles
I have no advice on removing the paint except to say I do not think that you should power wash the shingles You were not directly saying that you would but you did mention it...
Good luck on a remedy, does it actually show to the world or just to you?
meboatermike is offline   Reply With Quote
Old 10-31-2009, 11:38 PM   #3
Default If you had gribbled green paint whould you care?
You could get some green spray paint and 'dust 'the spot and make them blend in
Old 11-01-2009, 12:00 AM   #4
I just read on Yahoo answers or somewhere like that to use a power washer.
It basically just shows to me. I doubt anywhere else would notice unless they were looking. Things like that bother me though, since I'm the one that let it happen.
Old 11-01-2009, 12:02 AM   #5
I have thought of that and might do it if nothing else works. It just gives it a less than professional look. So far everything else is looking great.
Old 11-01-2009, 12:31 AM   #6
You know that you can't remove the paint without damaging the shingles.
Old 11-01-2009, 12:39 AM   #7
I've read that and I've also read to use Oops or alcohol.
I did a Google search and someone suggested getting roof repair tar and spreading it over it to make it black and blend in a little.
If I just dust it with gray/blackish spray paint, it will look 100% better and most people won't notice it. It's just a bright white spot on a dark gray shingle.
Old 11-01-2009, 12:51 AM   #8
gather some granules out of the gutter--Sprinkle them on the "camo" paint,It works,only you will know.-M-
Old 11-01-2009, 01:51 AM   #9
That would work great. Unfortunately I just cleaned my gutters last week. I had a ton of granules. Hopefully I still have some left to use.
Old 11-04-2009, 06:23 PM   #10
Drywall contractor
Whatever you do, DON'T use a pressure washer. It will take all of the granules off of the shingles and you will be in worse shape than just some paint spots.......
If you can read this, thank a teacher. If you can read this in English, thank a soldier. Support our troops.
bjbatlanta is offline   Reply With Quote
More On This Topic
Roofs last along time, so it's entirely possible you have owned a home without ever having to pick replacement shingles. Or, it has been such a long time there are new products on the market from which to choose. Pick replacement roof shingles by... Read More »
We're going to do some more splattering so I'm going to show you how to build a splatter shield. So you want to get a piece of plastic or a piece of glossy printing, possibly from some junk mail and you want to fold it over in half and tear a random... Read More »
This is Kevin with Expert Village one day bathroom makeover. This particular paint job we let it dry for approximately a hour and 45 minutes to 2 hours before peeling off the paint the tape excuse me that boarder the paint job. Special type of blue tape... Read More »
Knowing the properties and uses of paints will save a great deal of time, money and work over time. The right paint choice will help the finish last its longest and look its best. Read More »
Now we're going to create a splatter shield because we're going to be doing some splattering on this one. So basically it's going to be 8 1/2 by 11. Full sheet 11 by 17. Just use anything they send you in the mail that you don't want. There's lots of... Read More »
Remove Pipe Vent from Asphalt Shingle Roof WaldenL Roofing 5 09-26-2009 03:46 PM
Replacing chimney flashing after new shingles tmiles2246 Roofing 17 06-01-2009 10:27 AM
IKO Shingles - beware mtugrad1985 Roofing 7 02-10-2009 05:42 PM
Shingles Bubbled Up rjordan392 Roofing 3 05-06-2008 01:23 AM
shingle over??? lemeno Roofing 12 12-02-2007 01:39 AM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
