How Do I Remove Residue From A Wall Before Painting? - Painting - DIY Chatroom Home Improvement Forum
Old 08-16-2014, 03:51 PM   #1
How do I remove residue from a wall before painting?
Should I use TSP or something else to remove this residue? Should I prime the blue part of the wall only and then paint?
http://imgur.com/Iw9yjkW
http://imgur.com/Qb0ZwXE
How do I remove residue from a wall before painting?-image-1593588182.jpg   How do I remove residue from a wall before painting?-image-82747765.jpg
dinosaur1 is offline   Reply With Quote
Old 08-16-2014, 04:17 PM   #2
Rewards Points: 1,192
What is the residue from, wallpaper, tape, sticky shelf paper, etc.
ED
de-nagorg is online now   Reply With Quote
Old 08-16-2014, 04:20 PM   #3
Remodel and New Build GC
MTN REMODEL LLC's Avatar
Rewards Points: 5,622
Residue Remover.......?
MTN REMODEL LLC is offline   Reply With Quote
The Following User Says Thank You to MTN REMODEL LLC For This Useful Post:
ToolSeeker (08-16-2014)
Old 08-16-2014, 04:25 PM   #4
Old 08-16-2014, 04:36 PM   #5
Jmayspaint's Avatar
Rewards Points: 534
Scrub it, hot water alone may work where it hasn't been painted, depends on what it is. The painted areas will need sanding.
Jmayspaint is online now   Reply With Quote
Remove part of conc basement wall stadry Concrete, Stone & Masonry 13 04-17-2013 05:25 AM
Remove wall at recessed window boogie81 Building & Construction 7 04-06-2013 04:07 PM
Can I remove this wall..? (Image) findlay70 Building & Construction 8 04-27-2011 06:02 PM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 07:23 PM
Painting Kitchen Cabinets, Back wall NewlywedKristin Interior Decorating 12 03-18-2010 11:23 AM
