Old 01-01-2008, 02:49 PM   #1
how do I remove light and plug plates
how do I remove light and plug plates that are sealed on tight without damaging the wall around them? I'm thinking that they were put on wet paint and sealed themselves. I'm a new owner of an old house and would like to change paint colors and / or just the plates for brass ones. Tara
catara is offline   Reply With Quote
Old 01-01-2008, 03:11 PM   #2
Oldguy
Rehabber's Avatar
Use a razorknife and cut around perimiter.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
Old 01-01-2008, 03:13 PM   #3
Bathtub Refinisher
Take a razor knife and trace around the cover. Go around a couple of times. Then try to pry off.
Mike
tubguy is offline   Reply With Quote
Old 01-01-2008, 03:15 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
They will need to be pried off
As a painter I use a 5-in-1 tool, (which is really a 38-in-1 tool), but some regular sort of putty knife should do it
Sometimes the end of the putty knife needs a wack with a hammer, almost like a chisel, to get those things off
There's no guarantees, it depends on how they were stuck, but usually they come off w/o little or no damage with a little prying and/or a light wack
5 in 1:
putty knife:
slickshift is offline   Reply With Quote
Old 01-01-2008, 05:33 PM   #5
okay, next question how do I paint so it is not so blotchy? I don't understand why it isn't the same as painting a canvas.
Old 01-01-2008, 07:40 PM   #6
slickshift's Avatar
Oh, it's real different
Different paint, different tools, different substrate...
Old 01-01-2008, 11:29 PM   #7
Chicagos Green Contractor
GreenContractor's Avatar
what kind of paint are you using?
GreenContractor is offline   Reply With Quote
Shed: One light, one plug Crackers Electrical 2 08-31-2007 06:09 PM
Glow plug warning light is flashing spidenkin Automotive Repairs 1 07-18-2007 04:41 PM
Polarized plug light fixture- Hardwire to home electrical? timdavis3824 Electrical 3 07-09-2007 01:34 PM
converting hanging light fixture to plug dukeswalker Electrical 2 09-18-2006 10:03 PM
Switching from light socket to plug - stupid question CGofMP Electrical 5 03-25-2005 10:48 PM
