-   -   How do I remove excess deck stain? (http://www.diychatroom.com/f4/how-do-i-remove-excess-deck-stain-4270/)
McBerry 10-09-2006 07:59 PM
Greetings-
I applied a coat of stain to my deck on Sunday, and, before I left for work this morning, applied some extra to a few spots that I felt needed it. As it turns out that may have been a bad decision, as the spots where I applied additional stainer appear to be drying with a much darker color. There is also a very sticky residue on those spots as well.
My question is this-should I remove the excess stainer now while it's still wet, or wait the full 24 hours to let it dry and hope/pray that it blends in? If the former, what product should I use? Or do I have to re-do the entire deck?
Many thanks in advance!
slickshift 10-09-2006 08:29 PM
Wipe it off right now!
Go!!!
McBerry 10-09-2006 08:39 PM
Go!!!
Seriously? What is the consequence if I don't? Will it dry in a discolored fashion?
Do I use a solution?
slickshift 10-09-2006 08:56 PM
What are you doing typing?
Go now!
Wipe it off!
Really!
Just use a clean rag, preferably with no lint
It's the best chance you have to even out the finish
It may or may not work, but you have to try
If the spots are really darker, then there's not much you can do later
Another coat over the whole thing to make it all darker, and maybe blend the spots better
But enough of this chit-chat
Wipe up what you can!
Paintguy26 10-09-2006 10:30 PM
yeah....what slick said!
When you are staining a general rule is to keep lint free rags with you and wipe up any puddling as you go. This is very important~I guarantee the can you are using says to remove any excess as you apply.....
*Stain is like semi-gloss paint....you can never touch it up without repainting the whole darn piece.
McBerry 10-10-2006 02:40 PM
Well, I tried wiping off the excess last night but it was too late, as the wood had already absorbed most of the additional layer. I woke up this AM and the deck had pretty much dried, but now with a rather large dark splotch in one area.
I am an idiot.
I guess I'll have to do the entire deck over again & live with the much darker results?
redline 10-10-2006 07:25 PM
Or remove the dark sections. Either flip over the boards or put in ones that are not as dark
crecore 10-12-2006 04:48 PM
If you're good you can sand that spot down and restain, blending out with auto body precision. :) Flipping the board is not a bad suggestion IF it's a new deck and top screwed... if the wood was faded on top the flipped board wont match anyway. :( If hidden fasteners were used you're really out of luck. :mad:
