How Do I Prime And Paint A Pine Wood Toolbox? - Painting - DIY Chatroom Home Improvement Forum
Old 11-22-2012, 07:21 PM   #1
How do I prime and paint a pine wood toolbox?
I made a toolbox of pine. the outsides had been sanded but what type of primer and paint do I use?
890763 is offline   Reply With Quote
Old 11-22-2012, 07:31 PM   #2
Rewards Points: 12,794
I'd concider using an oil based primer and an enamel paint.
Reason being enamel is a really tough paint and will hold up to being wiped done well.
Old 11-22-2012, 08:36 PM   #3
Too Short? Cut it Again!
You should use a sanding sealer and then a primer on pine---or a combination product. A tried and proven sealer for pine is 1:1 PROCESSED (not raw) lindseed oil and a solvent like paint thinner or mineral spirits. You just have to wait out the solvent evaporating and do a light sanding before putting on your enamel underlay primer. Finish with two coats of finish.
Something like Ben Moore's porch, floor and patio paint would give you good factory color choices (or a custom mix) and the oil based product comes with urethane reinforcement and the waterbased with epoxy reinforcement. The paint might hold up better to tools nicking it than standard exterior or interior paints.
I saw a custom toolbox with truck bed liner sprayed on the interior and I bet that held up pretty well. A local place that does truck liners would probably do your toolbox interior for next to nothing when they were doing a larger project? I suspect an auto supply store sells the stuff in some form too?
Old 11-22-2012, 09:10 PM   #4
Rubbin walls since'79
Brushjockey's Avatar
For a tool box I would go with a stain finish- won't show the abuse so much.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 11-23-2012, 06:53 AM   #5
Doer of Many Things
poppameth's Avatar
Rewards Points: 576
I usually hit pine with a shellac sanding sealer to keep the knots from bleeding. Then follow up with oil primer and paint. Urethane oils like porch paint and industrial enamel will hold up best.
Darkling Designs
poppameth is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
To prime wood door or not? Rav Painting 11 07-25-2012 05:41 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 11:00 AM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 11:18 AM
Flashing NoExperience Painting 13 09-04-2008 06:56 AM
