How Do I Paint Sheet Metal/duct? - Painting - DIY Chatroom Home Improvement Forum
Old 10-22-2009, 09:14 AM   #1
New Home Owner
How do I paint sheet metal/duct?
As in this thread, I have a hole I will be covering up with a piece of sheet metal. I would like to paint the sheet metal, as well as the duct.
I tried using vinegar to etch, then using a latex primer, but it scratches off very easily.
Should I be using a spray paint? Any ideas?
Brandon19 is offline   Reply With Quote
Old 10-22-2009, 09:21 AM   #2
Too Short? Cut it Again!
You shouldn't have a problem if you use a nice thick bonding, stain blocking, latex primer like Benjamin Moore or MAB Superbond (will stick nicely to just about anything but plastic). If you can get it where you live, you might be better off with an oil-based primer on metal but again, get a good one like Benjamin Moore Fresh Start or a paint store recommend specifically for metal but alkyd in chemistry so that it will take latex as a finish coat (unless you plan to use oil for it).
Old 10-22-2009, 11:15 AM   #3
(the original)
Rewards Points: 756
And just to give you some more choices, SW's All Surface and Zinsser Bullseye 123 are formulated for galvanized. But did you correct the duct problem?
ratherbefishin' is offline   Reply With Quote
Old 10-22-2009, 03:00 PM   #4
you can also use the Sherwin Williams pro industrial pro-cryl latex primer with any latex topcoat. this stuff is amazing, one of the best rust inhibiting primers i have ever used.
markmay121 is offline   Reply With Quote
Old 10-22-2009, 03:00 PM   #5
ohh and i forgot to mention it is very costly but worth it if you want it to last a lifetime
Old 10-22-2009, 03:45 PM   #6
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Use a good bonding primer, then you can top coat with an acrylic or you can save a step and use DTM primer/finish which you can get at sherwin williams. DTM is direct to metal. Procryl is also great stuff from Sherwin Williams.
housepaintingny is offline   Reply With Quote
Old 10-23-2009, 07:34 AM   #7
New Home Owner
i used some 1-2-3 and i'll let that cure for as long as possible. i scratched a bit by accident an hour after and it came off, but i'll let it dry more.
thanks all
Old 10-23-2009, 11:52 PM   #8
CAD
I don't know much about house paint on metal but scuffing up the metal with a sanding disc or something would help it stick. Some 60 or 80 grit would probably work ok.
CAD is offline   Reply With Quote
Old 10-24-2009, 08:58 AM   #9
Matthewt1970's Avatar
Rewards Points: 1,098
We have a winner. DTM is what you wat to use.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
Semi gloss on Semi gloss mattpricemn Painting 6 08-25-2008 07:18 PM
