How Do I Know If I Messed Up With Polyurethane - Painting - DIY Chatroom Home Improvement Forum
Old 06-20-2010, 07:33 PM   #1
how do i know if i messed up with polyurethane
i painted a table black and then put a coat of polyurethane. when i sanded it down to put second coat of poly it left the surface with a white foggy look. do i go ahead and apply second coat and it will dry clear or did i mess up
juliusbugius is offline   Reply With Quote
Old 06-20-2010, 07:43 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Off-hand (w/o seeing the project), sounds pretty normal
slickshift is offline   Reply With Quote
Old 06-20-2010, 07:58 PM   #3
i have never used poly before and didnt know what to expect. i was so scared i messed it up. so i am assuming after wiping it down and apply second coat of poly it should dry looking clear and shiny over black paint, hopefully
im not sure if this is a duplicate or not but if a foggy look is normal then i assume after i wipe it down and apply second coat it will dry clear and shiny over black paint......hopefully. and what is the best type of brush or sponge is best to use?
Old 06-21-2010, 10:51 AM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
Sounds normal to me too.
Problem - Polyurethane bleaches out Stain Color on Maple Table GhanaBhuti Painting 9 09-05-2011 10:50 AM
Particles showing through the polyurethane over my newly-sanded hardwood floors proofer Flooring 3 12-10-2008 08:42 AM
oil vs water poly batwoman Flooring 6 09-30-2008 10:00 PM
Minwax Polyurethane vs. Minwax Polyurethane Floors proofer Flooring 3 04-06-2008 08:48 AM
Staining Wood Floor -- Use Polyurethane or FLOOR Polyurethane? proofer Painting 2 04-05-2008 07:47 PM
