How Do I Clean Walls For Painting? - Painting - DIY Chatroom Home Improvement Forum
Old 06-04-2009, 09:41 PM   #1
How do I clean walls for painting?
What is the best way to prep my walls for painting. I just bought the house and it smells from smoking and pets. There are also dirt marks on some areas. I used a steamer and wipe all the walls down. Was that a good thing. do I still need to wash them?
jeffhweb is offline   Reply With Quote
Old 06-05-2009, 06:44 AM   #2
NAV
for the smoke/nicotine stains it can be helpful to wash the walls with a solution of TSP and water.
for the pet smell it's not as easy. Most of the smell is probably coming from the floors. you may have to tear out all of the existing carpet and prime the walls ceilings and floors with BIN - an alcohol based primer by Zinsser.
NAV is offline   Reply With Quote
Old 06-05-2009, 12:25 PM   #3
thanks
thanks for the tip
Old 06-05-2009, 12:27 PM   #4
Tsp?
Is there seomthing I can use besides TSP? I heard it's pretty potent stuff and I need a mask. I heard about mixing detergent with water. Is that ok?
Old 06-05-2009, 01:38 PM   #5
Haste Makes Waste
I used Ultra Dawn (not regular Dawn) with some white vinegar (neutralizes) and liquid fabric softener (fragrance) with hot water. It worked great for me. I was cleaning wallpaper residue from a plasterered wall. If you like, add a little baking soda to work as a scouring agent. Animal skin oil smell from dogs came out of my carpet with a professional cleaning. If it is animal urine, good luck. Shampoo carpets without getting too wet (I use Chem-Dry) or it will help the pad underneath saturate with diluted urine . Good luck. It should clean up okay.
Also, there was nicotine on my walls. It cleaned up great.
Also, I'd prime to seal it before painting.
saggdevil is offline   Reply With Quote
Old 06-05-2009, 02:58 PM   #6
cleaning walls for paint
Thanks for the tips!!
How to clean smoke from fire, off walls jerbark General DIY Discussions 6 04-27-2009 04:29 PM
Replace exterior walls or build false walls Medic507 Carpentry 3 11-12-2008 10:48 AM
Keeping Water out of the Top of Brick Walls o2barockstar Roofing/Siding 4 02-18-2008 03:50 PM
