How To Deal With Cracked Fascia Board? - Painting - DIY Chatroom Home Improvement Forum
Old 05-11-2013, 02:03 AM   #1
Rewards Points: 452
How to deal with cracked fascia board?
See all the cracks in the fascia board?
spackle or caulk or what?
pman6 is offline   Reply With Quote
Old 05-11-2013, 03:34 AM   #2
Rewards Points: 6,652
Is there a hidden meaning in this picture? My fair guess is that wood is old, and most likely Cedar. In my neck of the woods, we call that aged appearance, and it adds character. As long as you keep it painted, prep before repainting each time, every few years, you will be fine.
Old 05-11-2013, 06:00 AM   #3
I agree with Greg. As long as it's maintained it won't cause any problems, and it is common among older buildings. I see that all the time. If it bothers you you can fill them with spackle, sand, prime then finish. However, spackle doesn't have a great track record for holding up outside. Maybe in LA it may because you don't have the temp extremes common in the midwest and northeast. The difference in expansion/contraction rates between wood and spackle causes it to fail/separate in a lot of cases. When I say spackle, to avoid the controversy that term creates, I don't mean joint compound. Depending upon what's available to you behind the Iron Curtain that is California, get a good quality exterior patching/filling compound.
Old 05-11-2013, 12:15 PM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
That would be a lot of caulking and it will probably just crack more in the future. It would be easier to just replace it but I am with jsheridan and Greg, just leave it.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 05-11-2013, 12:40 PM   #5
Jmayspaint's Avatar
Rewards Points: 534
Something like "peel bond " might bridge some of those cracks. It's a really thick primer. Finish with a heavy bodied acrylic. That would help seal moisture out without caulking.
I caulk a lot of cracks like that but it is time consuming. Caulk won't totally hide the crack like spackle/filler can, but I think it holds up better.
Jmayspaint is offline   Reply With Quote
Old 05-11-2013, 02:33 PM   #6
Rewards Points: 13,694
Have it covered with Gray PVC coil stock and never have to deal with it again.
Old 05-11-2013, 02:55 PM   #7
Rewards Points: 452
Yeah, that would be a crapload of caulking.
This fascia board is on the west side of the house, and gets the most intense sun.
not to mention, it's been neglected.
So the cracks are definitely not adding character.
I have seen videos where someone has used Bondo filler on outside corners of fascia board, and claims it resists cracking and opening up. But I've always had my doubts.
Anyone here use bondo successfully?
http://youtu.be/xXXmKheE1ZQ
Originally Posted by gregzoll View Post
Is there a hidden meaning in this picture?.
nope.
Just want the fascia smooth like the rest of the house.
Old 05-11-2013, 03:04 PM   #8
Jmayspaint's Avatar
Rewards Points: 534
Automotive body fillers like bondo don't have a great track record for exterior use over time. I've heard that epoxy/marine type fillers will hold up Better in cases like yours.
The Following User Says Thank You to Jmayspaint For This Useful Post:
Gymschu (05-12-2013)
Old 05-11-2013, 03:04 PM   #9
Rubbin walls since'79
Brushjockey's Avatar
I have had a similar problem, and as said, any filler will eventually fall out.
I hit mine several times with Peel Bond, as thick as i could hang it on.
About the best solution I found short of replacing boards.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 05-11-2013, 04:08 PM   #10
Too Short? Cut it Again!
Until moisture sneaks between the facia and the PVC.
The Following User Says Thank You to user1007 For This Useful Post:
kwikfishron (05-11-2013)
Old 05-11-2013, 10:54 PM   #11
Bondo would work but it is a royal pain in the butt to sand.
Old 05-12-2013, 02:41 AM   #12
retfr8flyr's Avatar
I would either cover it with some aluminum trim or replace it with Hardy Plank fascia. I have all brick but all the trim and fascia is Hardy plank on my house and it is great.
retfr8flyr is offline   Reply With Quote
Leaking between gutter and fascia board Jo Wag Roofing/Siding 3 03-10-2011 07:54 PM
5/8" Fireboard (Paint) meets 1/2" Cement Board (Tile) LeviDIY Building & Construction 9 02-09-2010 09:41 PM
Cracked cement board floor under laminate dmozealous Flooring 1 05-07-2009 09:06 AM
Help with Roof Leak ak1mking Roofing/Siding 15 11-14-2008 01:55 AM
replacing fascia board joefromcal Roofing/Siding 12 08-18-2008 06:33 PM
