How To Cover Caulking Marks? - Painting - DIY Chatroom Home Improvement Forum
Old 03-29-2009, 05:09 PM   #1
how to cover caulking marks?
Hi everyone, new...here i have checked out your blogs for months now, and finally decided to join. OK my question is, i have been redoing my kitchen for the past month 1/2...awful trouble painting my cabinets....long story, but anyway, the main issue now is i went w/ semi-gloss paint, which i love the sheen, but now everywhere i have caulked looks awful, i tried to sand out the caulk but it seems to gumm up....any suggestions? Desperate help, just want to get finished!!
cmerchant is offline   Reply With Quote
Old 03-29-2009, 06:18 PM   #2
Rewards Points: 506
Maybe you can post pics of the problem you are having? I'm having trouble picturing it.
SirWired
sirwired is offline   Reply With Quote
Old 03-29-2009, 06:25 PM   #3
Remodeling Contractor
You will need to remove the caulking. What type did you use and where? When applying the cauling again, tape off both edges and tool the caulking with a metal spoon dipped in denatured alcohol to give a perfect smooth joint.
Old 03-29-2009, 08:52 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
Welcome aboard!
Looking awful is kinda vague, what looks awful about it?
Does it look thick and much too noticeable?
Or is the paint alligatoring where you caulked, or not sticking?
slickshift is offline   Reply With Quote
Old 03-29-2009, 10:43 PM   #5
When we caulk we always use a wet rag to remove any edges. Its difficult to remove these edges once they have been painted over. You can try a very sharp scraper. Remove the caulk and sand area smooth. Just remember after you caulk an open joint, smooth with finger, then wipe with a wet rag removing excess caulk. Good luck.
waynech is offline   Reply With Quote
Painting Vinyl Sasha2000 Painting 9 04-11-2009 07:47 PM
Central Air Outside Unit Cover czars HVAC 2 01-07-2009 10:23 PM
Where stucco meets the window & door; caulking Longleaf Building & Construction 12 08-12-2008 04:46 PM
Fascia cover filled with water/ice causing leaks brianbh Roofing/Siding 10 02-11-2008 07:34 PM
Patio cover Jackhammer Building & Construction 3 07-10-2007 03:49 PM
