How Cold Can It Be - Polyurethane - Painting - DIY Chatroom Home Improvement Forum
Old 10-22-2011, 10:48 AM   #1
jschaben
Rewards Points: 502
How cold can it be - polyurethane
Got some Minwax polyshades. Boss wants a door polyed and installed by Tuesday but I have to work outside.
It's about 50*F now and given my schedule getting two coats on by Monday PM gonna be close. Can I start now? Can doesn't give any temp range.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 10-22-2011, 04:23 PM   #2
I think you'll be okay John, though fifty degrees is about the low end for stain. I would at least try to set yourself up in the sun, and remember that drying times are dependent upon temp, so give a little extra time between coats. Maybe a splash of Jap drier would be helpful. I would also try to get it inside somewhere as soon as it's dry enough to handle, and not let it sit out overnight. The drop in temps and possibility of dew may give you problems.
Old 10-22-2011, 05:57 PM   #3
jschaben
Rewards Points: 502
Hi Joe, thanks for the comeback. That's a relief as I went ahead with it. Temp was about 58 at the time and it got near seventy with 3 mph wind and 30% humidity so I got pretty lucky. Hope it holds as I gotta do the other side tommorrow.
Had to smile when you mentioned adding Jap drier, he**, I'm lucky to get a new Wal-Mart foam brush out of 'em
Since I'm working alone tommorrow, I'm bringing my HVLP in to do the other side.
I work Friday through Monday and when I came in yesterday was first I heard of this. They told me it was ready to finish...... It took two more hours this morning with my ROS to get it there.
John Schaben
Where to find correct polyurethane caulk for foundation cold joint? mikegp Building & Construction 4 07-17-2011 05:22 PM
Hot Water Turning Cold - Could it be the washer/dryer? kissiffer4 Plumbing 3 01-28-2010 04:47 PM
Cold air return questions ekulrenlig HVAC 19 10-09-2009 01:44 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 06:59 AM
Help with low pressure cold water upstairs lewissv Plumbing 5 01-26-2007 08:05 AM
