How Cold Can I Spray Latex Paint? - Painting - Page 3 - DIY Chatroom Home Improvement Forum
Old 11-11-2011, 04:04 PM   #31
Rewards Points: 4,796
I guess I assumed from your post you had an airless sprayer because you were talking about latex. Even a Wagner Power Painter runs at 2,200 I think. Mine goes up to 3,000 and it's not close to industrial. What sort of sprayer are you talking about?
jeffnc is offline   Reply With Quote
Old 11-11-2011, 04:25 PM   #32
Is this wire Hot?
Oh-Fudge's Avatar
Rewards Points: 170
This one: Titan Vaper 19418 Siphon Feed Spray Gun
Quick Overview
The Titan siphon feed spray gun features a 1.8mm fluid nozzle and needle, making it ideal for spraying heavier materials.
Details
Model-19418.
1.8 mm fluid nozzle and needle.
Ideal for spraying heavier materials.
Fully adjustable spray pattern.
External mix for fine atomization.
33 oz. aluminum paint canister.
1/4 in. inlet.
47 CFM.
5060 PSI.
Oh-Fudge is offline   Reply With Quote
Old 11-11-2011, 05:16 PM   #33
jschaben
Rewards Points: 502
Quick Overview
Details
Model-19418.
1/4 in. inlet.
4–7 CFM.
50–60 PSI.
Need an air compressor to run that. Airless pumps the paint through.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 11-11-2011, 06:05 PM   #34
That would explain the failure to pump at 3,000 psi :-)
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
latex paint over oil-based = peeling paint! help! ImaDIYnewbie Painting 5 09-20-2010 04:48 PM
problem - latex paint over oil paint theis96 Painting 3 03-14-2009 12:44 PM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
Re-Painting textured walls: the Frustration New2DIY Painting 20 07-06-2008 03:10 PM
