How To Clean Paint On Laminate Floor? - Painting - DIY Chatroom Home Improvement Forum
Old 04-25-2011, 11:30 AM   #1
How to clean paint on laminate floor?
I have some paint drops on my laminate floor. Is there any products that I can use to clean it up?
agapediy is offline   Reply With Quote
Old 04-25-2011, 12:12 PM   #2
waterman1971's Avatar
Rewards Points: 154
Wet rag should do the trick.
waterman1971 is offline   Reply With Quote
Old 04-25-2011, 02:18 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
If it's dried denatured alcohol, or even rubbing alcohol will soften it. Then gently scrape.
I'd save the single malt scotch though. But in a pinch...
Brushjockey is offline   Reply With Quote
Old 04-25-2011, 04:13 PM   #4
ltd
Rewards Points: 536
water,rag,thumbnail
ltd is offline   Reply With Quote
Old 04-25-2011, 06:16 PM   #5
Handyman
Rewards Points: 512
Wait until it dries and use a cheap PLASTIC scraper..follow along with a vacuum.
canadaclub is offline   Reply With Quote
Old 04-26-2011, 01:34 AM   #6
You can apply the stain cleaner on the spots and let it set for one to two minutes.
myfourseasons is offline   Reply With Quote
Old 04-26-2011, 04:11 AM   #7
If it's not dry, why wait till it is?
Old 04-26-2011, 06:14 AM   #8
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
If it's latex....
tcleve4911 is offline   Reply With Quote
Old 04-26-2011, 02:35 PM   #9
Handyman
Rewards Points: 512
Yeah Sheridan..that was kind of a dumb comment wasn't it What I was thinking was after paint has left small marks and semi dried...best to let it dry and scrape otherwise you just get the dried rings left over.
I will not drink anymore...I will not drink anymore...I will not...AH, forget it
Dave
The Following User Says Thank You to canadaclub For This Useful Post:
jsheridan (04-26-2011)
Old 04-26-2011, 03:07 PM   #10
Too Short? Cut it Again!
If it is not sharp or thin enough, use plastic razor blades. Usually if the laminate finish is decent it will come off with a wettry terry cloth.
The razor blades will come in handy for other things and they are nice because they do not rust like the steel ones.
http://www.scraperite.com/
Ready to paint the porch! Oil or latex? Leah Frances Painting 10 08-24-2015 02:59 PM
Ditra under Laminate Floor? HECO Flooring 3 04-30-2012 08:00 AM
Laminate floor in basement questions vesh1717 Flooring 2 11-26-2010 12:06 PM
Oil based paint over Latex? No need for Primer? Jasonuncloned Painting 2 10-20-2010 10:33 PM
Hardwood Floor Painting Advice / Tips / Tricks? cherie Flooring 3 09-05-2008 09:52 PM
