How To Change The Sleeve Of The Roller Paint? - Painting - DIY Chatroom Home Improvement Forum
Old 07-26-2010, 08:06 PM   #1
How to change the sleeve of the roller paint?
I thought I can found the answer easily on the web,unfortunately no luck.I have used a roller paint last year,and I want to change the roller "brush", it seems to be stuck , any help is appreciated.
toumert is offline   Reply With Quote
Old 07-26-2010, 08:19 PM   #2
might be easier to just buy a new roller setup. You should remove them at the end of using them, paint gets inside and dries. it is like glue. you can also try to cut the roller off using a utility knife. but be very careful. these blades are sharp.
merle is offline   Reply With Quote
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 08:46 PM
1st Steps in Painting? Qckrun Painting 7 12-15-2009 01:25 PM
Wet paint roller before using saggdevil Painting 3 06-02-2009 09:03 PM
Painting a room for new baby. Lots of questions. SuperAkuma Painting 15 01-01-2009 11:18 AM
Re-Painting textured walls: the Frustration New2DIY Painting 20 07-06-2008 04:10 PM
