Old 07-02-2012, 03:40 PM   #1
How can I repair scratches in cherry wood?
Bought this iPod dock (which I believe is cherry) with a few scratches all over. What is the best way to repair these? Thanks.
smokey847 is offline   Reply With Quote
Old 07-02-2012, 04:58 PM   #2
the Musigician
DangerMouse's Avatar
Carefully remove everything that is not wood then strip, refinish and reassemble.
DM
[SIGPIC][/SIGPIC]Click
to see some of my original magic tricks and trick boxes!
Old 07-02-2012, 06:38 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
What Dm said- or if your not too fussy this will make them go away pretty much with a little finesse
Just get the right colors..
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 07-02-2012, 06:59 PM   #4
sdsester's Avatar
You might try tinted wood putties or tintable wood restoration epoxy products. Abatron would be the company with products I would trust in the latter cases.
Melting crayons of the right color to fill the scratches and then applying and buffing out a paste, restoration, or bowling alley wax as a new surface finish might work. You will have trouble getting poly, varnish or whatever to stick to wax though. You will gum up sandpaper trying to sand it.
There are some special scratch repair products out there but most seem gimmicky to me. This doesn't mean the would not work. I just have no experience with them.
Stripping and refinishing is probably your best bet though if you want the best shot at doing this right. If it has lots of scratches you should decide, as suggested, how much you want to put into this. You could just fill, sand prime and paint with rattle cans if it is not wort trying to match the wood. It is kind of a nice looking piece though.
sdsester is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Repair wood fence tran1267 General Discussion 3 05-10-2010 09:47 AM
Repair wood floor scratch borderman01 General Discussion 4 05-07-2010 05:13 PM
Bathroom Wood Rot Repair drerock Kitchen & Bath Remodeling 6 04-29-2010 10:53 PM
Cherry Wood steveotti Carpentry 6 03-11-2008 08:21 PM
