How Can I Remove Dried Epoxy Resin From Hardwood Flooring? - Painting - DIY Chatroom Home Improvement Forum
Old 03-21-2010, 11:04 PM   #1
How can I remove dried epoxy resin from hardwood flooring?
Can anyone help? I have accidentally spilled some epoxy resin on my hardwood floor and it has dried. Any ideas?
Kay Manuel is offline   Reply With Quote
Old 03-22-2010, 08:41 PM   #2
I assume you're talking about two-part epoxy adhesive or resin. I have cured epoxy resin stuck to the concrete floor in my garage. I think it will outlast the concrete.
Sorry, but I think you're out of luck. Even if you were willing to sand it off and refinish the floor, the wood around the edge of the epoxy will sand down long before the epoxy. You'll end up with an outline around the spot where the epoxy was. Perhaps a large drum floor sander would be able to smooth it off.
If it's a high-visibility spot, I'd recommend consulting a floor finishing pro. They might have some tricks up their sleeve.
houseinthewoods is offline   Reply With Quote
The Following User Says Thank You to houseinthewoods For This Useful Post:
Kay Manuel (03-22-2010)
price of vinly flooring compared to laminated hardwood flooring dollyooooo Flooring 1 05-13-2009 12:29 PM
Installing Prefinished Hardwood Flooring Around Kitchen Island bioman Flooring 4 03-25-2009 06:18 PM
Flooring hardwood v engineered or laminate skits Flooring 1 07-12-2006 09:03 AM
hARDWOOD FLOORING CHERRYCAKE3 Flooring 1 03-08-2006 02:44 PM
Installing Help! hardwood flooring in Hot&Humid weather dvarga Flooring 7 08-08-2005 05:45 PM
