How Best To Cover Uneven Finish In Satin Paint - Painting - DIY Chatroom Home Improvement Forum
Old 01-14-2013, 12:38 PM   #1
Rewards Points: 38
How best to cover uneven finish in Satin Paint
Hello,
The first time I applied satin paint (SW emerald) to new walls in a home I overworked the paint and was too slow. The end result was satin paint that had many roller marks and uneven finish. I have gone back with better technique and tried covering the marks to some success. However some marks remain. It is mainly areas where the sheen is "dull" that seem to stay.
I'm wondering if I should sand before I coat the walls with issues again. There isn't really imperfections in the way of ridges you can feel. Like I said its more of a sheen issue. Would sanding the entire wall a bit beforehand help my cause or would it create more issues? Any other recommendations on how to cover these areas?
Sdiver2489 is offline   Reply With Quote
Old 01-14-2013, 01:51 PM   #2
That's a tough one. Satin is brutal paint to work with on walls, even for pros, especially if you have strong sidelighting. A certain level of glitch is to be expected. Even without "overworking" it, just the time involved in going from the wall to the tray and back it can set up enough to glitch on you, where it "crushes" or mats the sheen. The best advice is to keep the temp cool in the room, thin the paint with a bit or water or extender or both, keep the roller wet, and work your ass off. I rarely work with satin on walls and do everything I can to deter my customers from using it.
Old 01-14-2013, 04:04 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
Joe- I think SW's satin is more like BM's matte- under an eggshell.
But it is a technique issue - sanding won't help.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 01-14-2013, 07:18 PM   #4
You know BJ, after I posted that I thought about the last couple of times I used a satin wall finish. The one time was an SW satin and I do remember now it not being quite the sheen I expected from a satin, and wasn't as difficult to work as I was expecting. At least when I compare it to what I think was my use of BM Kitchen and Bath for a powder room, why I don't know, and the sheen was higher than I liked. It sometimes all just blurs together. I was cleaning a brush today that I had wrapped in plastic. It was still fresh, a deep burgundy, and for the life of me I can't remember what I painted recently that was that color, a complete blank.
Old 01-14-2013, 07:25 PM   #5
Honestly I really don't like Sw much, but I have heard the sheen of LoLuster Ultra spec to be similar to SW's satin. And that seems pretty mello..
Old 01-14-2013, 07:28 PM   #6
I don't care for it much either. I use it on occasion but mostly Ben Moore.
Old 01-15-2013, 02:40 AM   #7
paper hanger and painter
chrisn's Avatar
Rewards Points: 612
[QUOTE=jsheridan;1093636]You know BJ, after I posted that I thought about the last couple of times I used a satin wall finish. The one time was an SW satin and I do remember now it not being quite the sheen I expected from a satin, and wasn't as difficult to work as I was expecting. At least when I compare it to what I think was my use of BM Kitchen and Bath for a powder room, why I don't know, and the sheen was higher than I liked. It sometimes all just blurs together. I was cleaning a brush today that I had wrapped in plastic. It was still fresh, a deep burgundy, and for the life of me I can't remember what I painted recently that was that color, a complete blank.[/QUOTE]
oh, ooh
chrisn is online now   Reply With Quote
Old 01-15-2013, 08:49 AM   #8
[QUOTE=chrisn;1093836]
oh, ooh
I know, right.
Old 01-15-2013, 09:06 AM   #9
Rewards Points: 6,034
Would Japan drier help with the issues.
Old 01-15-2013, 09:09 AM   #10
Japan driers are only for solvent based finishes.
The Following User Says Thank You to jsheridan For This Useful Post:
ToolSeeker (01-15-2013)
Repainting Room With Peeling Paint: Advice Needed Magnetic Painting 8 10-15-2012 05:19 PM
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 07:38 PM
NEW DRYWALL, new addition, Need Primer chipraynor Painting 50 11-09-2011 11:45 PM
How to cover textured paint? camillac Painting 2 10-12-2009 08:58 AM
semi gloss enamel vs eggshell enamel NoExperience Painting 18 03-05-2009 04:57 AM
