House Exterior - Painting - DIY Chatroom Home Improvement Forum
Old 02-26-2013, 04:46 PM   #1
house exterior
Thinking about painting my house this spring, planned on using a sprayer, single story house, nothing fancy. Is this something I should try on my own or might this be a bad idea.
clarc31 is offline   Reply With Quote
Old 02-26-2013, 04:49 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Spraying is much harder to do right than it looks. Unless you know what you are doing- bad idea.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 02-26-2013, 04:54 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 312
what he ^ said for sure
The Following User Says Thank You to chrisn For This Useful Post:
Gymschu (02-26-2013)
Old 02-26-2013, 04:57 PM   #4
Thats why I asked, thanks
Old 02-26-2013, 05:31 PM   #5
What do you guys think about rolling and brushing a house
Old 02-26-2013, 05:42 PM   #6
cdaniels's Avatar
It's the way I have painted houses for 25 years.I don't spray at all.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
The Following User Says Thank You to cdaniels For This Useful Post:
Old 02-26-2013, 05:48 PM   #7
Any tips? Im a little nervous about messing it up if you cant tell
Old 02-26-2013, 06:01 PM   #8
cdaniels's Avatar
Make sure you have the right nap for your needs,make sure you have plenty of drop cloths and masking materials. What type of siding do you have on your house.? Prepping correctly is the key to a good paint job.
Old 02-26-2013, 06:04 PM   #9
The house is an aluminun siding, garage is some sort of tile? Asbestos maybe? Not real sure, see it on a lot of houses though
Old 02-26-2013, 06:10 PM   #10
cdaniels's Avatar
I think I know the tile or shingles that you mean.They probably are asbestos.I have rolled and brushed many over the years.The aluminum siding would probably be better brushed but if it is chalky...it will need a good cleaning and priming.
Old 02-26-2013, 08:34 PM   #11
Rewards Points: 13,458
http://www.sherwin-williams.com/home...oatings/paint/
This is what I use on aluminum.
Deck footings closer than 5' to an existing exterior house wall oatlord Building & Construction 9 09-05-2011 10:12 PM
Exterior House Paint. Williebee Painting 3 05-31-2011 03:42 AM
My Summer: Exterior remodel on my dad's house housegsx Project Showcase 25 04-05-2011 09:56 PM
dealing with exterior slope towards house. organick Building & Construction 26 03-19-2011 02:57 PM
Sealing exterior wall from inside the house? BigJimmy Building & Construction 6 03-20-2007 09:16 PM
