Holes Left By Curtain Rod Screws/anchors..what To Do? - Painting - DIY Chatroom Home Improvement Forum
Old 05-31-2009, 04:06 PM   #1
holes left by curtain rod screws/anchors..what to do?
I'm a newbie at this.. so bare with me. I've decided to paint my bedroom. I took down my curtains and curtain rod, and then realized that the screws and anchors holding up the curtain rod were starting to pull out of the wall (My apt. is very old, and the walls are quite crumbly from all the layers of paint applied over the years.) I went ahead and pulled them out completely, and now have even larger holes in their place.
Now, what do i do?
Do I just fill in these holes with spackle and then install the curtain rod a few inches above them? Or is it better to create new holes to the right of them? Or does it not matter?
talula79 is offline   Reply With Quote
Old 05-31-2009, 05:35 PM   #2
the Musigician
DangerMouse's Avatar
Originally Posted by talula79 View Post
so bare with me.
i don't think the wife would let me....
however, do you have pics so we can see how big the holes are?
what is the material? is it plaster wall? drywall? theoretically, you'd patch, paint and then mount the brackets fresh.
DM
Old 05-31-2009, 06:33 PM   #3
forgive me for not knowing whether my walls are plaster or drywall. (i don't know the difference!). They're crumbly and awful. The holes are about the size of a dime, and are probably and inch or more deep. But I like the idea of mounting the brackets wider than my window.... thanks for that suggestion.
Old 06-02-2009, 10:28 AM   #4
kimberland30's Avatar
From what you are describing your walls are probably plaster (crumbly). We have plaster walls as well and anytime we remove a nail or screws from the wall, there is a large hole left behind.
I prefer the spackle that is pink when wet and dries white - that way I know exactly when it's hard. For putting up new rods, I've always put them either to the side or above where they were prior to moving them.
kimberland30 is offline   Reply With Quote
Old 06-03-2009, 09:05 AM   #5
RippySkippy's Avatar
however, do you have pics...
C'mon DM! Keep it clean this is a friendly place...but there are limits....
To the OP...the spackle should work fine...and the ones that change color work well. That big though...don't get in a hurry and paint before it's fully dry as it may require a couple of applications.
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Tags
anchors , curtain rods , painting , walls
foundation weep holes for drainage shama144 Building & Construction 12 12-31-2011 11:17 AM
Re-using post holes in concrete philS Building & Construction 8 05-04-2009 08:15 AM
Vent pipe boots -holes eaten in them N. Duval Roofing/Siding 3 02-03-2009 07:52 PM
Basement holes WinnipegCouple Building & Construction 2 09-02-2008 07:12 PM
drilling vent holes ape Roofing/Siding 4 10-15-2007 04:36 PM
