High Luminosity; Zero-VOC Paint - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 04-21-2010, 12:52 PM   #16
Rewards Points: 270
Originally Posted by BMDealer View Post
I believe Harmony is zero VOC until you put colorant into the can. Could be wrong though.......Natura is the only product that I know of that starts zero VOC and ends zero VOC in any color. Competitors can not say or do the same..........Natura comes in Flat, Eggshell, and Semi-Gloss.
I'm liking Natura more and more as I read here (and elsewhere). But curious - in the shop here (local building supply) where I found BM products, I thought they also had some other brand(s) - my crappy memory might be wrong but if that's the case, would they have a separate mixer and tints for each brand? sorry if this is a dumb question, but how do I, in all my paranoia, know they're not adding tints with VOC's to a non-VOC can of Natura?
rtoni is offline   Reply With Quote
Old 04-21-2010, 08:48 PM   #17
Just as another option as far high reflectivity, stop in SW and in their low and zero voc paints, there is a paint base called luminous white or has been renamed high reflective white, this is a very bright clean white, they have a seperate color chart for these colors that are a cleaner and brighter set of colors, you can use the white by itself but doesnt cover as well as the regular dirty whites.
paintpimp is offline   Reply With Quote
Old 04-21-2010, 09:42 PM   #18
Toe
Guess I should update this thread, since I'm done painting now.
In the end, I took a chip of paint from a relatively low-use room and asked a Benjamin Moore dealer to match it. Their match came out a little lighter than the original, but this might be because the super-cheap original had discolored and gathered dirt over the years.
I wanted to color-match because, in the end, it was the easiest option. That way, I could get away with not painting every inch behind the stacked washer/dryer, for example.
The BM Natura is a superb paint. One coat was sufficient everywhere (though I did prime over certain spots that were new drywall, etc.). It had pretty good coverage, but it was a little difficult to spread. Low-VOC paint in general, and Natura especially, dries extremely quickly. This made the traditional rolling technique (get a bunch of paint up there, then even it out) impossible, because it would dry shortly after I put it on the wall. After some practice, I figured it out, but it was a bit of a pain.
I has one can of Sherwin-Williams Harmony which I used in a couple of bathrooms (as the color was slightly different). It had noticeably better spreadability. However, the coverage was horrible. I think the full can got about 300 square feet, compared to the 400 ft average.
Overall, I found the BM Natura to be superb. After I was done, everything looked fantastic. And though there was a hint of a lingering paint smell (I have a super-sensitive smell), it was nothing compared to conventional paint.
Toe is offline   Reply With Quote
Old 04-22-2010, 12:32 PM   #19
Rewards Points: 270
Toe - thanks for the info on Natura - what did you use for the primer - Does Natura line include a primer / sealer?
Old 04-22-2010, 02:16 PM   #20
Toe
There is a Natura primer, but I already had Sherwin-Williams Harmony Primer from a previous job. It worked fine. However, despite being zero-VOC, it had a very strong paint odor.
I should also note that my notes above were about the flat latex I used on walls.
I also painted much of my trim. For that, I had a gallon of S-W Harmony semi-gloss which made it through much of the job. It was very thick and gooey: not at all as spreadable as the S-W flat. I finished off the job with a quart of the BM Natura semi-gloss, and it was much more spreadable. It went on a little thin, but overall was just much easier to work with than the SW. (Though I admit that my SW was like a year old.)
My conclusion: given a new job, I would stick with the Natura. It is expensive (as is the Harmony), but clearly a very high-quality paint. And walking around the fresh-painted house, my super-sensitive nose could only pick up a little paint smell. There is an even more expensive BM paint, Aura, which is only low-VOC but claims to have even less odor. But the zero-VOC living environment is a plus in my book.
Old 04-22-2010, 02:36 PM   #21
Rewards Points: 270
thanks again Toe
Just for kicks, I spent a few minutes (more searching) today and found quite a few (some very recent) negative reviews on this paint (e.g. very bad smells for weeks / months, etc). Some people even claiming they couldn't use the rooms until repainting with something else.
Could it be that much of a crapshoot? BM seems like a solid company - there must be some quality control - maybe some old paint was sold/used - does it have a shelf life? From some of the descriptions I'd have to guess there's something else going on - how could it be that bad in some cases...?
Just seems weird - people either really love it, or (a few anyway) really really hate it.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Flashing NoExperience Painting 13 09-04-2008 05:56 AM
does high quality bargain paint exist? erica Painting 6 06-22-2005 05:53 AM
