High Heat Vs Reg - Painting - DIY Chatroom Home Improvement Forum
Old 01-16-2012, 02:50 AM   #1
high heat vs reg
I just painted an old brass wood burning glass fireplace door with rustoleum flat black paint... and as soon as I jinished I thought of high heat...
think it will be good or will it give off fumes?
I can either give it a coat of high heat over top of the regular paint, or I can find a hammer...
takaya is offline   Reply With Quote
Old 01-16-2012, 07:02 AM   #2
DIY staff
Rewards Points: 7,174
Those doors don't get that hot---Give it a try and see how the paint holds up---I think you will be fine.
Old 01-16-2012, 07:32 AM   #3
Too Short? Cut it Again!
I would not worry unless you have to either. However, if you find yourself in a fail situation, putting something like a barbecue or engine paint over the top is not going to get you very far. You cannot use paint to seal problems. You will have to strip what is on and falling off. Sounds like if you were thinking of a hammer you are not wild about the thing in the first place? Maybe it is time for something you like better before sinking lots of money and time into this.
Old 01-16-2012, 08:46 AM   #4
Actually I do like the regency ci1250 more but can't afford it this year
So I picked up glass doors for $20
I will make the opening fit both so switching over is easy..
I'll leave it for now since removing doors and redoing isn't more than a days work
Can I connect Honeywell Vision PRO 8000 (1 Heat/ 1 cool) to a Heat Pump w/aux for heat coils? TimDavis HVAC 12 01-18-2012 08:06 AM
Using Gas heat during Defrost mgroves HVAC 15 12-18-2010 06:51 PM
Heat pump or high efficiency furnace moisheh HVAC 13 11-14-2010 12:59 PM
Ducane heat pump high head PoleCat HVAC 6 07-09-2010 04:28 PM
Heat Pump Blower always on gg_daman HVAC 1 12-16-2009 07:15 AM
