-   -   Help wood stain showing through paint (http://www.diychatroom.com/f4/help-wood-stain-showing-through-paint-2038/)
laviticus 03-14-2006 11:53 AM
Could any one recommend a way or product to stop wood stain coming though paint.:confused:
thanks
slickshift 03-14-2006 12:20 PM
You either need primer/sealer or a solid color stain
What is the situation and products used or wanted to use?
The specific steps would depend on the situation
laviticus 03-14-2006 03:04 PM
Hi slickshift,the previous owners of the house stained the wooden dado rail and managed to get it on the plaster too, we painted it with white gloss paint when we moved in, a year later the stain came through and the stain on the plaster seeped through the wallpaper too.
MinConst 03-14-2006 05:07 PM
You need to prime with a product like Kilz. It will seal the stain in and not allow it to bleed through.
slickshift 03-14-2006 09:06 PM
Ah, you'll need a sealer or primer/sealer, sometimes called a stain blocker
Original Kilz (oil-based) should work
Maybe go with Zinsser's BIN (shellac-based) just to be sure
With either please follow the precautions on the can
You'll want some fresh air and a respirator
More so with the BIN
laviticus 03-15-2006 02:55 PM
thanks guys will try that.....:D :D
AAPaint 03-17-2006 11:35 PM
Follow the advice of the respirator and fresh air. BIN should not be taken lightly for interior use. If you're doing more than a spot or two open the windows and get a fan going.
