HELP! What Color Should An Interior Door Be Painted? - Painting - DIY Chatroom Home Improvement Forum
Old 02-06-2009, 10:42 PM   #1
Exclamation
HELP! What color should an interior door be painted?
We have pine wood trim throughout our house. Most of our walls are some sort of a neutral color. The ceiling is a standard ceiling white. What color should all of the interior doors be painted? The wall color? Ceiling color? An accent color? HELP!!
dx Decorator is offline   Reply With Quote
Old 02-20-2009, 11:20 PM   #2
Painter
Talking
Usually the trim and the color of the doors are the same. If you can't stain the doors to match the existing trim, you may look into painting the base boards, door jams, and doors all the same shade of white. It looks really good and modern with neutral color walls. I suggest using a semi gloss, when at your local paint store ask for trim paint, it may cost a little more but it is more durable. Now having said that remember, it is your house and your the one that has to look at it everyday. So it is really up to you.
Stephanie
Srother9 is offline   Reply With Quote
Old 02-20-2009, 11:55 PM   #3
I have red doors, green doors, blue doors, white doors, off-white doors
White walls, red walls, blue walls, yellow walls, green walls, purple walls
white trim, eggshell trim, green trim
To me it's what you like
Smoothing out a painted and not painted drywall surface MarksHouse Drywall & Plaster 5 10-21-2008 12:50 PM
Sheetrock mudding over existing painted textured surface? SKINNY Remodeling 8 10-13-2008 01:00 PM
Painted Tub With Epoxy, Didn't work.. Need your advice diyfan902 Painting 1 03-11-2007 04:55 PM
