Help! Used Wrong Stain On Deck. - Painting - DIY Chatroom Home Improvement Forum
Old 09-27-2011, 04:51 PM   #1
Help! Used wrong stain on deck.
I bought Rust-oleum Premium Composite Deck Stain. I started to stain my deck with it, but my deck is pressure treated wood. It took the stain and looks great. I am not sure if I should continue with it and if it will be ok to use. It dried right away. Any Ideas. Mu husband said to finish it with that stain because it looks great. Not sure. Any Ideas. Thanks
sduquette is offline   Reply With Quote
Old 09-27-2011, 07:28 PM   #2
Rewards Points: 282
stain is stain...if it took then the wood is "stained"
if there was going to be any bad reaction it probably would have already happened. you can probably get in touch with rustoleums R and D department and ask someone, i'm sure they have tested it on PT.....they try to do the stupidest things they can think of that consumers may do with these products! They will probably say "well, we cant recommend or warranty it, but no adverse effects were noted"..etcetcetc
durability may be an issue, but only time will tell (and it also may not be an issue).
i would also just finish it and see how it looks in a year to decide what to do next.....
jcrack_corn is offline   Reply With Quote
The Following User Says Thank You to jcrack_corn For This Useful Post:
sduquette (09-28-2011)
Deck stain help... bcbud3 Painting 6 07-03-2010 11:14 PM
Need advice on deck flashing, water stain Durt Ferguson General DIY Discussions 4 04-20-2010 06:09 PM
cement pool deck... acrylic, epoxy or stain? vickipalma Painting 4 09-17-2009 02:09 PM
deck stain removal phatibs01 Painting 7 06-07-2009 09:10 PM
What is the best way to apply stain to a deck? flashme18 Painting 4 04-24-2008 10:23 PM
