HELP!! ST700 Airless - Painting - DIY Chatroom Home Improvement Forum
Old 05-20-2014, 03:55 PM   #1
HELP!! ST700 airless
Hi everyone! I am new here and am really excited that I found you guys (and Ladies!). I have an ST700 Wagner airless sprayer that is about 30 years old. It worked fine until I tried to clean it this last fall. Now it is not working properly. When I turn it on it pressures up fine. after I pull the trigger and expend the pressure the machine will not pressure up. if I turn my knob to flush the machine bubbles come out of the paint can for a lil bit before it becomes a stream of water again. at this point if I turn the switch over to paint then the airless will pressure up fine. after pulling the trigger the scenario starts all over again.....Can anyone tell me what I did wrong?!! thanks in advance!
mrjimmyc is offline   Reply With Quote
Old 05-20-2014, 09:07 PM   #2
Rewards Points: 386
um…the knob you turn to flush the machine…is that your prime valve? …if so, are you priming your pump before filling and pressurizing the line?
ric knows paint is offline   Reply With Quote
Tags
air gun , airless , sprayer , wagner
Wagner ProCoat airless - $180 jettlash84 Painting 1 05-10-2013 10:09 PM
Removing Airless Sprayer Paint Runs Twister Painting 8 10-08-2011 08:04 AM
When to rent airless sprayer? schraggyj Painting 7 04-06-2011 09:19 AM
Best airless sprayer to stain deck zach70287 Painting 4 03-03-2011 08:12 PM
airless sprayers Neil_K Tools 2 08-14-2005 09:17 PM
