Help!!Sherwin WIlliams Lingering Odor - Painting - DIY Chatroom Home Improvement Forum
Old 09-07-2008, 06:47 AM   #1
Help!!Sherwin WIlliams lingering odor
Has anyone had a problem with residual fumes (months later) a very cloying smell which will not go away? I read a blog called Ghost Odors by an environmental professor who described the same situation exactly. Sherwin Williams does not seem to be acknowledging the problem. After months of living with this I now want to know what to do to neutralize what's on the wall- this odor-(latex ) before painting with Benjamin Moore. Help. I,m miserable.
Leslie Razook is offline   Reply With Quote
Old 09-07-2008, 08:59 AM   #2
No. We've been using Sherwin Williams paints in our custom homes since 1980 and have never had a problem or a complains about paint odor.
I heard there was a paint formulation issue with some Sherwin Williams paints back in 2002 I think but they had corrected the problem.
KHouse75 is offline   Reply With Quote
Old 09-07-2008, 11:42 AM   #3
Tired, Cold, and Damp
slickshift's Avatar
Not knowing to which specific product you are refering, I can only say that SW as a whole does not have excessively stinky paints
(there are other companies/lines that do)
However, that's small consolation to those that are sensitive to these things
The only fix for paint odors is as much airing out as possible...with fans etc.
The best fix to seal in odors in the walls, is unfortutately a shellac, which itself is extremely stinky, but dries quick as has no odor to speak of when cured
If you want/need to skip the ultra-stinky
shellac, the best suggestion I have would be to use two coats of ultra-low VOC Aura
slickshift is offline   Reply With Quote
Whirlpool dishwasher odor Captflx Appliances 8 06-26-2009 08:40 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
New Construction Odor Bewildered1971 Building & Construction 12 06-25-2008 09:39 PM
Sulphur odor in upstairs area ksherbak Plumbing 3 02-14-2008 03:39 PM
Waste pipe odor in garage? Kirsten Plumbing 3 11-21-2006 12:07 PM
