HeLp! To Sand Or To Paint? Ceiling Issues - Painting - DIY Chatroom Home Improvement Forum
Old 01-13-2013, 08:58 PM   #1
Question
heLp! To sand or to paint? Ceiling issues
Before repainting my ceilings I did some drywall repair work. Two of the areas that had major repair work done are showing through the first top coat. I sanded to what I thought was good enough, primed, sanded and now top coated with first layer of pm200.
Im doubting the final top coat will hide the history of the repairs. Some of the area can be slightly felt, other parts can only be seen. The pictures dont show the flaws very well, but to give you an idea take a look.
Do I need to remove more mud?
Adrenalinejunky is offline   Reply With Quote
Old 01-13-2013, 09:30 PM   #2
cdaniels's Avatar
It's hard to tell but it looks like it needs sanding and more mud to me.I would sand it as smooth as I could get it and skim it out wider.The wider you skim it the less gradual the patch will be therefore less noticable.
Charlie Daniels painting and repair
cdaniels is offline   Reply With Quote
Old 01-13-2013, 10:38 PM   #3
ltd
Rewards Points: 536
yep also at least a 10 inch drywall knife is a must .your right. no top coat will hide that
ltd is offline   Reply With Quote
Old 01-14-2013, 12:10 AM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
That looks like some heavy texture on that ceiling. If it is a texture then the game will have to change. For now a 10" blade as ltd suggested and you may even need to wet sand the edges with a sponge if the sandpaper is not getting into the texture to smooth it out.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 01-14-2013, 09:15 AM   #5
It started out as a straight crack from wall to wall. Muded and taped it and it was spread out about 3' wide...
Ok thank you for saving me the time and material in another coat.
It's a smooth ceiling, the only minimal texture is from the roller pad. So wet sanding will accelerate taking out the edge? I was thinking of even trying a palm sander, especially considering it sounds like I'll need to mud again..
Old 01-14-2013, 09:44 AM   #6
Rewards Points: 5,974
I would suggest even with a 10" knife you may need to go 10" on both sides of the crack the farther you go out the less noticeable the repair and make them thin coats. Then on a ladder with a bright light held at an angle you can pretty much tell what is going to show when painted.
The Following 2 Users Say Thank You to ToolSeeker For This Useful Post:
Adrenalinejunky (01-15-2013), Brushjockey (01-14-2013)
Old 01-14-2013, 04:58 PM   #7
Rubbin walls since'79
Brushjockey's Avatar
Personally I think wet sanding doesn't get as smooth and flat as using a hand sander that has a flat platform. The light while sanding is essential.
I'd use a 12" blade, but a 10 is sure better than a 3.
You need to fan it out so it leaves no hump. or indentation.
This painting stuff is tricky, eh? lol
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following 2 Users Say Thank You to Brushjockey For This Useful Post:
Adrenalinejunky (01-14-2013), ToolSeeker (01-14-2013)
Old 01-14-2013, 09:06 PM   #8
Sand and then fan out more mud?
Yes I wonder how much it would've cost for labor to repair walls and paint...
Old 01-14-2013, 11:16 PM   #9
If what you have done has been painted, its really hard to sand then. So I think all of us are saying it is fanning out the joint compound better and sanding that.
The Following User Says Thank You to Brushjockey For This Useful Post:
Old 01-15-2013, 09:46 AM   #10
Ok that sounds better, I was going to use a palm sander otherwise to break through the paint and primer layers.
Old 01-15-2013, 01:56 PM   #11
Rewards Points: 744
After you've feathered it out and sanded, get up on your ladder with a bright flashlight. Hold the flashlight parallel against the ceiling and shine the light over your repair. This should give you a pretty good idea of whether or not you've feathered it out well enough at that point.
Seattle2k is offline   Reply With Quote
The Following User Says Thank You to Seattle2k For This Useful Post:
Adrenalinejunky (01-17-2013)
Old 01-17-2013, 01:57 AM   #12
After first coat I did some sanding... Applied 2nd coat only to area concern rather than entire repair, like first coat. Hopefully after sanding it will have improved. Ive been hearing about level 5 finishes, and using the water & mud skim coat applied with a roller... Everything Ive seen on this is on new drywall vs. drywall repairs. Anyone have experience with this finishing method?
Old 01-17-2013, 03:44 AM   #13
cdaniels's Avatar
Drywall repairs can be tough on us so I can imagine you are having a little trouble.I still say skim it out wide.12" knife on both sides of the joint. Pull the knife tight against the ceiling.The more excess you can wipe off wet the less you have to sand off dry.It may take you a few tries but you can get it flattened out.
Old 01-17-2013, 04:45 AM   #14
paper hanger and painter
chrisn's Avatar
Rewards Points: 232
You will never end up with a level 5 finish, no matter what method you use and using a roller to apply mud certainly will not work for you. There is no earthly reson for a level 5 finish on a ceiling. You are way over thinking this.
The Following User Says Thank You to chrisn For This Useful Post:
ltd (01-17-2013)
Old 01-17-2013, 08:15 AM   #15
Rewards Points: 4,792
You don't need a level 5 finish. What you need is to get a level 4 finish not perfect but near perfect. I sometimes apply level 4 with a roller, but that's a different matter. You need to thin the compound a bit to do this, but that doesn't make it a level 5 finish. It's just the 3rd compound layer.
You probably should use a 12" taping knife, but if you have a 10" now that should work.
jeffnc is offline   Reply With Quote
Tags
ceiling , drywall , prep , sanding
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
Painting over gloss paint on a Ceiling BSR Painting 7 08-23-2012 10:45 AM
SW Brilliance Ceiling Paint - Seeing Roller marks bentleyvt Painting 50 03-22-2012 12:33 PM
Ceiling Old&New Paint Issue tasmisr Painting 5 07-19-2011 11:19 AM
Bubbling paint on ceiling caused by damp bathroom floor garv19 General DIY Discussions 4 04-10-2010 08:38 AM
