Old 01-20-2010, 12:19 PM   #1
Help please...quick. Kilz dripping off walls
We bought a house with drywall that had not been taped and nails that were coming out. We dug out the nails and used screws,and taped the drywall after cleaning with vinegar and water the nicotine stained walls. We then went over the taped and screwed areas with joint compond and let it dry and prepped the areas. We put the first coat of Kilz on the walls and on the two outside walls the Kilz is still wet and dripping off the walls were the taping and screws are and the nicotine is coming through the rest of the same two walls. The inside walls and ceiling are fine. No bleed through and are dry. Help....what to do???? What is causing this?
jenllo is offline   Reply With Quote
Old 01-20-2010, 01:20 PM   #2
sdsester's Avatar
Kilz is really crappy primer and goes on too thin. No wonder it is sagging on you. And without knowing where you are, I am just guessing your exterior walls are too cold for the primer to cure like it should. You bought this at a box store didn't you? Would you buy donuts, fresh meat or veges and fruits from them? Why would you buy paint from them?
Hit your paint store. I forget the name but I restored a house where all including the infants smoked. It was a mess and just touching anything with a cleaner or solvent turned rags and sponges kind of a sick orange. I did that too by the way.
Sherwin Williams had a great oil-based primer that did the trick. Benjamin Moore Fresh Start, alkyd, not water-based, might do the trick but this stuff from SW was something hidden away.
You need an oil-based primer for this so hope you are alright with that? You want windows to be open when dealing with solvents.
You can put latex and acrylic over a nice solvent based alkyd, by the way.
sdsester is offline   Reply With Quote
Old 01-20-2010, 01:31 PM   #3
Thanks for your reply. I live in CT. I am going to go to SW today and try that. I'm just glad we haven't painted any other rooms. Live and learn.
Old 01-20-2010, 02:12 PM   #4
"Beam me up, Scottie"
Kevin M.'s Avatar
Hi Jenllo,
Vinegar has some limitations. It is quite popular considering it is a more natural cleaner. TSP is a cleaner and de-glosser. It is a chemical but not real intrusive. You can regulate the strength by water to mix ratio.
For any type of a glossy wall, or nicotine stained wall, it works real well to clean and prep the wall.
Kevin
Kevin M. is offline   Reply With Quote
Old 01-20-2010, 06:16 PM   #5
paper hanger and painter
chrisn's Avatar
Oil based primer MIGHT work, BIN primer WILL work for sure.It smells very bad, you will need respirators and ventilation but it is really the only primer that will seal nicotine, no questions about it.
http://www.zinsser.com/product_detail.asp?productid=10
Old 01-22-2010, 10:38 PM   #6
I hope you let us know how you resolve this.
All this time I have used oil based kilz, never knew I should have spent twice the money to get the job done .Hasn't always been necessary.
Did this house sit without heat for a long time? Strange predicament to me. I too wonder if the outside wall temps had something to do with this. And or moisture on the ouside walls.
Old 01-22-2010, 11:02 PM   #7
Love for Construction
<*(((><'s Avatar
x1000
Zinnser's BIN primer for the win!
My wife and I bought a 1950 sq/ft home that had been heavily smoked in. It was a long process, and here are the steps we took.
1) Open the windows as much as possible, this helped air the house out, but I've also heard the UV rays will help breakdown the oils and air pollutants.
2) Removed all carpet in the home.
3) Cleaned all the ducting with a mop and soap and water, reached as far back into the ducting as I could.
4) Replaced the return air filters, placed charcoal on top of the filters.
5) Left the central air fan on to circulate air through the filters, so it passes by the charcoal.
6) Washed all walls and ceilings with TSP/water solution (nicotine streamed down the walls), rinsed afterwards.
7) Primered all walls and ceilings with Zinnsser's BIN primer, this stuff is caustic smelling, but works like magic.
8) Painted everything with finish coats.
9) Mopped floors, installed carpet.
Now you can not even tell anyone has ever smoked in this house!
It was a LOT of work, and knowing what I know now, I would knock off about 10-15% off a houses price for the labor and materials to do the job.
<*(((>< is offline   Reply With Quote
Old 01-24-2010, 08:40 PM   #8
Just to echo the zinsser oil based primers will seal in the nicotine stains, but as pointed out, BIN is the best. Not so much because it will seal the stain better but because it will form a vapor barrier to keep out the smell!!
good luck!
mazzonetv is offline   Reply With Quote
Rotting shower walls PICTURE Sarah24 Kitchen & Bath Remodeling 6 05-10-2009 01:09 AM
Need help with very ugly basement walls GrandmaStormy Remodeling 5 03-05-2009 03:43 PM
Re-Painting textured walls: the Frustration New2DIY Painting 20 07-06-2008 04:10 PM
Need step by step instructions for fixing walls... Chianti Painting 7 06-20-2008 08:04 PM
help! my walls are troubled donnamarie General Discussion 5 08-29-2007 01:08 PM
