Help With Painting Unfinish Basement Ceiling - Painting - DIY Chatroom Home Improvement Forum
Old 09-12-2012, 12:47 AM   #1
help with painting unfinish basement ceiling
Hi
i just started spray painting my basement ceiling (unfinish wood). I tried my best to clean it very well and then I prime it was latex paint (lowes primer). I eventually spray it with latex paint (kilz 330 flat white).
The question I have is, there are still some areas of the unfinish wood showing through the paint (brown). Is there anything I could do to better hide certain areas? I have tried sprayng it with a additional layer but still couldn't hide the brown.
thanks
karlywu is offline   Reply With Quote
Old 09-12-2012, 03:23 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 234
Switch to a QUALITY primer and paint which means a trip to a real paint store.
chrisn is online now   Reply With Quote
The Following User Says Thank You to chrisn For This Useful Post:
karlywu (09-12-2012)
Old 09-12-2012, 06:40 AM   #3
Rubbin walls since'79
Brushjockey's Avatar
That raw wood is sucking in the primer. After the prime is dry it should seal the wood, so that the next coat of paint ( paint will cover better than primer- primer will seal and hold better than paint) will cover better.
You might be getting some knot bleed, and if you do you will need to hit those with shellac based BIN. a spray can of bin might be the way to handle those.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Old 09-12-2012, 11:41 AM   #4
thanks for the info
I will use shellac based BIN and cover those spots.
Painting over gloss paint on a Ceiling BSR Painting 7 08-23-2012 10:45 AM
Painting a wall that butts up against a popcorn ceiling... hikerguy Painting 9 08-07-2011 02:56 PM
Drywalling my basement ceiling luweee Remodeling 5 03-24-2009 07:58 PM
Five inch ductwork in basement ceiling - how to end the run? drnormie HVAC 5 11-25-2008 10:21 AM
Basement Ceiling- Combo of Drywall and Drop ceiling? H Thomas Building & Construction 5 03-27-2006 09:27 AM
