HELP - Painting Problem - Painting - DIY Chatroom Home Improvement Forum
Old 02-26-2010, 06:36 PM   #1
Hey guys, im in desperate need of your help and advice.
My dad has completed ruined my walls. My walls had mould on this so instead of using sugar soap to clean the walls.. he decided to use domestos bleach!!
Now he has not done an undercoat and decided just to paint straight on the walls. and not the domestos drip stains have come through the paint and you can see it down the wall.
Is there anyway we can fix this problem as i refuse to move into this room in that state. it looks discusting and no matter how many coats you do, it still comes through.
any advise to get rid of those drip marks?
munted is offline   Reply With Quote
Old 02-27-2010, 05:52 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
Needs to be primed with a stainblocking primer first.
chrisn is online now   Reply With Quote
Old 02-28-2010, 10:41 AM   #3
I agree. I use Bullseye 123. Check out their website to see if will work for your application.
Jawbreaker is offline   Reply With Quote
Old 02-28-2010, 12:52 PM   #4
Matthewt1970's Avatar
Rewards Points: 1,098
You may need something stronger like Kilz. Bullseye 123 is a weak stain blocker at best.
Old 02-28-2010, 06:24 PM   #5
chrisn's Avatar
Rewards Points: 228
Kilz oil will cover just about any stain,I just cannot take the smell,I use this when an oil is needed
Old 03-04-2010, 02:49 AM   #6
Finisher
Rcon is offline   Reply With Quote
window sash painting problem nerd_flanders Painting 1 08-18-2009 09:47 AM
Problem Painting Ceiling! Please Help! p00lbys Painting 3 06-06-2009 05:59 PM
Painting DensShield tile backer board warriorfox Painting 2 05-15-2008 05:08 PM
Painting over a sponge painted wall Snowdog Painting 3 03-17-2008 12:13 AM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
