-   -   HELP! Painted Bathroom with normal paint!! (http://www.diychatroom.com/f4/help-painted-bathroom-normal-paint-158850/)
itdel11 10-03-2012 02:04 PM
Hi,
I've recently had a brand new bathroom installed and stupidly have painted the ceiling with normal emulsion paint and forgotten to use 'Bathroom Paint'.....as I haven't used the bethroom yet, not had a shower etc, is it ok to just go over the top with a couple of coats of bathroom paint?? Or do I need to do a bit more to tackle the problem....
Any suggestions would be much appreciated!!!!!
johnny331 10-03-2012 02:11 PM
I used bathroom paint on the walls, but all my ceilings have standard paint... 5 years later the bathroom ceiling is fine.
jschaben 10-03-2012 02:16 PM
Originally Posted by itdel11 (Post 1022986)
Hi,
I don't see any need to panic... just paint over what you have. I assume by "bathroom paint" you are using a higher sheen in there. :)
Brushjockey 10-03-2012 02:24 PM
Please explain what the "normal" paint is, and what you think "bathroom" paint is-
You might be fine as long as it's not a dead flat- and if you have a vent fan in the bath.
itdel11 10-03-2012 03:16 PM
Thanks for the responses. At the moment I've just used Crown, White Matt Emulsion. With regards to 'Bathroom paint' I'm reffering to the kind advertised in B & Q / Homebase usually Dulux that say they're specially designed to withold moisture / mould etc....
Brushjockey 10-03-2012 03:25 PM
Because we have this ocean separating suppliers, I'm not familiar with the brand.
For the most part- you want a paint with at least a little sheen to give it some hold out from moisture. The ones that say for a bath usually have a little extra mildewcide in it also.
Every bath is different- most important thing is having a way to clear steam and humidity out. The worse your bath does that- the more important the moisture resistance of a paint becomes.
For the most part I recommend my clients use an eggshell finish, not flat or matte in baths. Even ( especially_ ) on ceilings.
user1007 10-03-2012 05:39 PM
We guessed from some of the terms you used that you are not on of us proud Norte Americanos. You might want to update your profile so we have a general idea where you are in the future.
The marketing ploy of kitchen and bath paint never took off well here. As mentioned, most of it is but waterbased acrylic/latex with a mildew agent tossed in. I suspect you can buy the mildicide and better paint in the sheen you want cheaper and just mix them.
It used to be baths were automatically painted with a semi-gloss but there is no particular reason to go that direction anymore. If there is adequate ventilation. Obviously if you take long 12 hour showers and expect the cubicle to dry out in the remaining 12 you are in for trouble with any paint.
Something like an eggshell will give you some sheen and I suppose added washability.
