Help-Paint peeling with blue painters tape
^^^yup^^^
You may have been better off pulling off the tape while wet, but it's also likely you were using the tape as a crutch to 'cut a line' rather than a tool to keep your work neat
No offense, and sorry if you weren't, but usually that's the case with this type of problem
Technically, your tape should be OK to leave for 7 to 30 days depending on what kind it is, so it's unlikely that is/was the only problem
Tape is supposed to be used to keep splatter off of where it's not wanted
Often people think that if they use tape, they can wave a brush full of paint in the general direction, glob it on, and it looks pro
Although it's possible that might work, it's more likely that the paint will leach underneath the tape, and the goobered paint on top of the tape will lift the old and/or new paint
