Help. Paint Disaster - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 06-18-2012, 12:55 PM   #16
jschaben
Rewards Points: 502
Originally Posted by Bookerc View Post
We had a similar experience when painting our kitchen. We wanted to paint it blue and yellow. Crazy color scheme I know. But, coming to the disaster, my wife painted dark blue where we had intended yellow. This was after scraping, cleaning, sanding, applying putty, sanding again, primer-ing, sanding and where the final two coats of glossy yellow should have gone we painted dark blue. . I was worried that the blue would be too strong and be seen through the yellow paint. We decided to try it out so just sanded it and scruffed it up a bit and painted it yellow on top. Second coat covered all the blue. An extra coat of yellow gave the wall a beautiful finish. Phew.
I've found in many cases that the lighter colors will cover better than darker ones. I think it depends on what base is used to mix the color with. Extra deep base mixtures don't seem to cover worth squat.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 06-18-2012, 06:45 PM   #17
Rewards Points: 2,218
john,
Just painted the den a medium taupe. It was 3 cream walls and one dark greenish blue wall.
I was surprised to see that SW SuperPaint in a medium taupe still shows a big difference in color, after 2 coats.
Wasn't sure whether to put a 3rd coat on the light colored walls or put a 3rd coat on the darker wall. Then decided I'm running out of time and it looks good so I'll leave it.
If I ever run into this again, I'd use primer on the darker wall to bring it more into the same color as the other walls.
Startingover is offline   Reply With Quote
Quick & Dirty Trim Salvage: Spackle to fill Old Chipped Paint? Lovegasoline Painting 13 09-01-2013 12:53 AM
Ceiling paint versus wall paint billyg Painting 6 02-09-2012 07:38 PM
Paint for Rust-Prone Exterior Metal Railings (Oil-Based Metal vs Epoxy vs Urethane) Einhorn Painting 9 06-19-2011 08:41 PM
Paint bubbling & peeling SamB Painting 2 04-28-2011 06:52 PM
latex paint on top of oil-based paint nancy-diy Painting 11 03-07-2010 03:02 AM
