Help My Primer Is Bubbling Up... - Painting - DIY Chatroom Home Improvement Forum
Old 09-29-2009, 09:42 PM   #1
Help my primer is bubbling up...
I have removed wallpaper from a wall... with tons of dings in the wall so I skim coated the wall 2 times and and sanded the wall until they felt baby smooth... primed the walls and all of where the joint compound was applied and sanded is bubbling up... help...PLEASE!!!
hollyjo213 is offline   Reply With Quote
Old 09-29-2009, 09:54 PM   #2
Too Short? Cut it Again!
You did wash the adhesive off the wall? What kind of primer did you use? Does it look like air bubbles or is the primer changing physically like paint stripper does? Is it settling down at all as it dries? Is it by chance a plaster wall?
Old 09-29-2009, 10:16 PM   #3
(the original)
Rewards Points: 756
Did you thoroughly clean all the dust off after sanding? Sounds like Kilz2 over compound dust....please say it isn't so
ratherbefishin' is offline   Reply With Quote
Old 09-29-2009, 10:26 PM   #4
no no and no.... I really goofed!!!!
I didn't wash the walls... i had skim coated over the entire walls....
how do I fix my mess up... can i put the oil based primer over the latex primer???
Old 09-29-2009, 10:51 PM   #5
Is this what it is looking like?
http://www.benjaminmoore.com/bmpsweb...eLabel=fa_home
My concern is whether you still have wallpaper paste on the walls and that is contributing along with the loose drywall dust to the adhesion problem. You can put an alkyd primer over latex but that is not the solution here I fear.
Old 09-29-2009, 10:58 PM   #6
nope doesn't look like that at all
just bubbles... now that the primer has dried some it is going away a little but still able to see some of it
Old 09-29-2009, 11:22 PM   #7
(the original)
Rewards Points: 756
You used latex primer, correct? Let it cure, then scrape/sand all remaining loose stuff and recoat with Zinsser Gardz.
Old 09-29-2009, 11:39 PM   #8
So the wall was dirty before skim coating?
In that case just scrape & sand as stated
Then skim coat any areas needed again
primer not adhering to drywall texture? eli_carson Drywall & Plaster 13 07-25-2013 09:00 AM
Paint blistering and/or bubbling issues stro77 Painting 8 10-06-2012 12:59 AM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 09:00 AM
help me pick a primer jheavner Painting 21 01-27-2009 12:30 AM
Painting Bare Steel- Sand First or Use Etch Primer? scott890 Painting 2 10-11-2007 05:32 PM
