Help Me Pick My Poison - Primer MDF , Poplar - Painting - DIY Chatroom Home Improvement Forum
Old 06-29-2012, 05:58 PM   #1
Rewards Points: 296
Help me pick my poison - Primer MDF , Poplar
All -
I don't have enough bin red to cover all...
Poplar is for trim. MDF is just access panels (millwork) in hinges that are flush to the wall to access utility meters, etc.
Which one to use on what.
I have tons of Fresh Start Premium (BM46), Gardz, some Bin Blue and just enough Bin Red to cover either or.
Second - when priming/sealing MDF, what's the proper technique . I used Gardz on ~green MDF--aka, moisture resistent MDF~ and got grain raise. I did a quick screen with 150 and it's good. The sides will need more loving and a 2nd coat of primer.
Or for all you pro's out there - just avoid it all and go run out get some more Bin Red ?
mobiledynamics is offline   Reply With Quote
Old 06-29-2012, 07:17 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
Which fresh start is the BM46? Raw wood really does best with oil primer. Guardz is more of a moisture sealing drywall primer.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 06-29-2012, 07:35 PM   #3
Rewards Points: 296
The Fresh Start has been renamed.
It's my goto drywall primer next to gardz.
http://www.benjaminmoore.com/en-us/f...6&advs=0&tab=3
Old 06-29-2012, 07:42 PM   #4
Rewards Points: 296
BTW, does BIN Red level well.
For the mdf panels, I'm inclined to brush the primer and then get the roller out for paint.
However...I won't want brush marks to telegraph through the paint
Old 06-29-2012, 08:20 PM   #5
Rubbin walls since'79
Brushjockey's Avatar
I haven't tried Gardz on raw wood or MDF. Seems like you want something with both pigment and sandability. I also think the bin is overkill- this is easier than that.
I would use the Fresh start - I am starting a remodel on mon with new wood to enamel, and will be using Primecoat 2 to prime the wood.
Finish in Aura Satin.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 06-29-2012, 08:24 PM   #6
Rewards Points: 296
Brushjockey :
Do you add any extender on the Satin.
Matte for the panels (same as wall) and satin is speced for trim
Old 06-29-2012, 08:27 PM   #7
The extender does help- I also will add just a bit of water too- only to my cut bucket- not the supply. Adjust as needed.. very little..
Old 06-30-2012, 05:26 AM   #8
So you have 3 primers that really shouldn't be used. Bin is a stain/problem solver. It can be used on wood or MDF but there are much better products. Guardz seals moisture from penetrating drywall, and straight latex primer raises the grain of the wood. A nice oil based primer is what you should be using.
Old 06-30-2012, 09:56 AM   #9
jschaben
Rewards Points: 502
I've been using BIN or Cover Stain on doors, Pine frames/MDF panels, for water base topcoats. I've been brushing the edges and rolling the faces with no problems. Neither seem to raise the grain nor adversely affect the MDF.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 06-30-2012, 11:09 AM   #10
The ol' time best of the best on raw wood was BM Oil Enamel underbody.
Not great on coverage but sanded to babys bottom.
That and topped with BM Oil Satin Impervo ( before the EPA porked it) and you had the top of the line.
Now I often can't use oil ( read stinky stuff) on jobs because everybody has been convinced they will die.
So other systems must be found. And the combination of technique and products= a system.
Old 07-01-2012, 06:09 AM   #11
paper hanger and painter
chrisn's Avatar
Rewards Points: 618
I still ( about once a year) come across a real old couple that insist on oil for everything. Now, it becomes a challenge to get. Times have changed
Free 5 gl of Behr Primer: Why Shouldn't I use it? Lovegasoline Painting 18 10-12-2013 07:47 AM
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Issues with primer on kitchen cabinets blinkandimgone Painting 4 08-17-2010 11:48 AM
help me pick a primer jheavner Painting 21 01-26-2009 11:30 PM
prepping old wood for painting newb questions afabco Painting 19 08-07-2008 11:19 AM
